Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: ciaoflyer on January 17, 2010, 05:37:31 PM
Here's one for you.
I was replacing the rear engine mount with a new one, removed it fine but noticed that the bolt's thread was a bit dodgy. ::)
Sure enough refitted it and the thread went >:( Now my engine has no rear mount!
What would be the best remedy for this?
The offending item......
(http://i32.photobucket.com/albums/d18/ciaoflyer/DSC_0018-1.jpg)
Could I get a slightly narrower, longer nut and bolt and thread it through the mount, through the old nut and then tighten it up?
I'd say try and find one at the breakers. These are special bolts (length and thread i think) so it'd be hard to find a new one (unless you buy from places like Axel Gerstl etc.) I tried to find bolts to the door lock mount at a tool shop (on the b pillar) but couldn't get any....
Do you think the nut will be knackered also?
a bolt is a bolt, the thread on the engine mount dont matter, aslong as other bolt is roughly same length or longer reckon you be ok, also thickness dont really matter as you could add a washer or 2
its a engine mount afterall
no doubt i will get slated for saying this but its my opinion
If you're lucky then the nut is fine...
Oye Mate , I think you're nut might be knackered :o
How can you even think about using a smaller size bolt to hold your engine in :oops:
Not Like it is a sidelight or something.
I do not have a 126 rear mount now but I think that from memory the bolt would go into a semi-captive nut which is probably a special but replaceable so do not panic.
Nice photo by the way ;)
Managed to get a replacement nut and bolt but a bit longer, if the nut is done in I shall drill it through and use the new bolt.
If the nut is still usable I have managed to get an identical bolt aswell so I shall use that!
My bolt like that snapped...spectacular noises resulted...
It it the same length and thread as that which holds the bell housing to the gearbox.
to be sure to be sure I have found a suitable nut which I believe to be a metric fine thread which was in a box of old Yamaha bits I have to act as a locking mechanism and a 'to be sure' if the thread was damaged.
Here's the old bolt and the new bolt
(http://i32.photobucket.com/albums/d18/ciaoflyer/DSC_0032.jpg)
new bolt is 10mm, slightly longer to pass through the old nut and then tighten up, also a sping washer and nyloc nut will be fitted to make sure it does not shake loose!
In ref to the original nut, our head technician at work says that the bolt has not been stripped but has at some point been loose and because of this the shaking of the engine has widened the grooves of the bolt and ruined it. Also the original bolt has a 1.25 pitch thread and, according to him, can support up to 4.5tonnes! :o
spot on , let me know hoe you get on, as i removed a ford courier towbar today and its got some tasty bolts like your original gold one .
laters
Is the new bolt the same strength (steel grade either 8.8 or 10.9 but could be stronger)? That's just as important as the thread when replacing a bolt...
Yes it's an 8.8 but has a wider pitch of 1.5, because the pitch is 1.5 it changes the strength to just over 4 tonnes, he said it would be fine...........
i might have a spare knocking around in my garage i will have a look when i get a mo.
Bearing in mind my bolt broke, it is a pretty valid question about the strength of that replacement bolt.
I'd carry a spare :oops:
So whilst tripping over an aircooled engine in my garage this morning I looked down on the mount. There is a baseplate that fixes to the crankcase with two bolts and that bolt goes into a deep screwed boss that is fixed to the underside of that plate. So if the Bis is the same why not replace the plate and get everything back to standard ???
Not sure what "widened the grooves of the bolt" means but if the threaded section has been stretched then it has been subjected to extreme tensile stress which I doubt on a bolt that size and in that application. From the photo the bolt does not look stretched as it would also have "necked in" or reduced in diameter at the point of max stress. For the bolt to be damaged it would either have worked loose or have been subjected to additional bending stress due to a side load in any direction , probably the cause of Darrell's bolt failure. Side loads on the bolt could be caused by front or rear impact on the car or worn / busted mounts at the gearbox end [-/
I know why my bolt broke :oops:
Sodding speed bumps...I kinda lost it with them as the one road is about 4 miles long with them and just floored it, well sort-of :oops:
So looking to do the 'bump stop' in the mounting trick the guys did here :oops:
Shhh don't tell the wife....I was late to collect her from work when it happened...
I promise I won't do it again sir :oops:
My gearbox mounts were shagged! Rusty do you think the bolt I am fitting will be ok? Also brakes arrive and look good - Cheers! [-/
The Bis has a plate sticking out the back of the engine, icould change this but where do I get one? Did have one on my old knackered engine but the 'travellers' pinched it off my drive along with a spare exhaust!
Other option is to remove old nut on bracket and weld a new one on...
(http://i32.photobucket.com/albums/d18/ciaoflyer/Eng04.jpg)
OK so it is a different bracket on the Bis, someone must have a spare kicking around. I guess that those gearbox mounts compounded the problem of probably a loose bolt. But in the meantime I would get that bracket off to assess its condition. Possibly run a suitable tap through to chase out & check what thread is left. You may get away with a longer bolt backed up by a lock nut. If the threads are totaly stripped & your gearbox mounts are fixed I think your bolt will be fine. Have fun with the brakes [-/
Fitted! It seems to work, all tightened up, ran engine and all seems fine. The test will be when I take it for a run! :D
Here's the knackered bracket before drilling through....
(http://i32.photobucket.com/albums/d18/ciaoflyer/bracket.jpg)
Nice thread :oops:
