Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: bobblehead on December 30, 2009, 07:48:41 PM
some twit drove into our ford courier van, and we think they might write it off, thing is battery is new and i was thinking about swopping it onto the 126 , it is a bit bigger in size ..
would this cause any problems if i was to swop it? would i burn wires out etc etd ??
says battery on a bis should be : 12 v 34 / 40 aph ..
courier diesal battery is : 12 v 62 aph
any help lads? shame to let new battery go with 2 years warrenty ?
From my limited knowledge of car batteries, in theory it should not be a problem except that the battery capacity should be compatible with the car's alternator. In other words, the 126 alternator will not be able to fully charge the other battery with a 62ah. So for example, the starter in an engine will typically quickly outstrip the capacity (measured in Ah or of Aph or amp-hour) the battery to keep cranking it for any length of time. A starting problem may occur with the 62ah battery because the 126's alternator cannot fully charge it. This is what I have been told in the past when I was looking for a larger capacity car battery for another car. The chap that advised me may be completely wrong or misleading. In the end, I have always bought the correct battery size.
Technically yes your correct the battery discharge rate should match your alternator but the size of the battery and alternator fitted is gaged by the expected maximum discharge of the car. As the expected maximum discharge rate of the car in this case isn't being altered (no fancy boom boxes, high discharge lighting etc. being added?) then yes it is better to fit the higher rated battery because you are just holding more reserve energy if ever needed (run out of petrol, leave your lights on etc.) the alternator will still cope with the standard disharge but will take slightly longer to fully charge the higher rated battery if fully discharged than it would to fully charge the lower rated battery which would have discharged itself sooner any way.
But be warned it is no good if it doesnt fit properly and can't be clamped down, I once witnessed an accident where a loose battery removed the bonnet of an XR3 involved and travelled 300 yards down the road like a scudd missile.
I read this post earlier and had thought along the same lines but didn't post anything as without facts these things sometimes sound like a guess! Put it this way, if you use this battery and have trouble starting one day, it'll take alot longer before the battery gives up! As DEfender 90 says, as long as it sits in the battery tray and can be clamped down then you're sorted.
All the above advice is correct, but it basically boils down to this one thing............
It will be fine, but as batteries have whats called memory effect, once its been on the 126 a while and the alternators provided the 55AH or whatever its rated at the battery will basically just become a 55AH battery as thats all you can put into it and its cells will deteriorate slightly. This is no porblem as long as you never want to put the battery onto something bigger again.
As an aside im an electronics technician as job, so any electrical questions, feel free to ask.
thanks lads, its on it fits, and starts and runs the same .... just feel abit better as its a new battery .. with 2yr gaurentee
