Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Rusty's Uncle on December 06, 2009, 04:40:11 PM
Title: Puffing not Hissing !
Post by: Rusty's Uncle on December 06, 2009, 04:40:11 PM
The last couple of times out in my little beast I noticed a slight drop off in power which is not good with a standard 499ccs motor plus the tick over speed lowered with the odd stall. So started the engine at home and with it running on the now slower tick over there is a definate puffing type sound, bit like a small steam engine. There is no sign of the head gasket gone as there are no emmissions at the hollow bolts. I disconnected the air intake & engine breather pipe & even the oil filler cap and its still the same. No signs of excessive crankcase pressure but covering the carb intake with my fingers so probably not air tight bought the engine revs up . Plugs are not loose either so any other ideas before I start stripping the engine  ???
Title: Re: Puffing not Hissing !
Post by: bis13 on December 06, 2009, 05:01:18 PM
was the loss of power not really noticable and is getting gradually worse? i had this when my cam wore down cant remember if it kept stalling mind. is it running on both cylinders?
Post by: Rusty's Uncle on December 06, 2009, 06:30:05 PM
You do not have to loose too much of the max 18bhp before you notice it especially when you live at the top of a great big hill. Firing on both & picks up on the throttle but if it was blowing gases or drawing air I would expect more of a hissing sound rather than this strange puffing on slow tickover  ::)
Post by: GTMaster on December 07, 2009, 05:30:01 PM
It might be the carb intake manifold gasket, that is it's sucking air in after the throttle plate (loss of power and possible puffing sound). Have a look around the intake. You mentioned that covering the carb intake made the revs go up so maybe there's too much air drawn in...
Post by: Rusty's Uncle on December 07, 2009, 07:37:51 PM
Hi GTM , yes that is my hopeful option as I have not had a chance to look at it yet but the carb did work loose this summer and I just nipped it down and it could be the gasket or a damaged inlet base section.  [-/
Post by: Pete126 on December 07, 2009, 08:14:20 PM
Another way to check if the carbs drawing in air at the gasket is if you have a gas blow torch turn it on and point it at the base of the carb with the engine running, if the engine speeds up, you've got a leak :)
Post by: bobblehead on December 07, 2009, 10:05:09 PM
or with it running spray wd40 on the carb and look for bubbles and see if engine dips or rises too
i think ?
