Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: bobblehead on December 05, 2009, 12:59:11 PM
Title: wheel bolts . ?????????
Post by: bobblehead on December 05, 2009, 12:59:11 PM
hi there i know we have been over this a million times, but i want to be sure :
ive got a fiat 126 bis . and i want to use cinq alloys on it , do i use my standard 126 bis bolts ??
the cinq wheel bolts ?
or something else ?
as my mate says if i used standard stock 126 bis bolts, they would come loose as they are not alloy wheel bolts ?
sorry to dig up old forum info ....
thanks
richard
pickk up coming along : www.dropshots.com/126picky
Title: Re: wheel bolts . ?????????
Post by: Eklipze3k on December 05, 2009, 01:08:26 PM
You can't use the cinq bolts as the thread is different (IIRC), I know the cinq/sei use M12x1.25 and I know my aircooled uses M12x1.5 so I assume the BIS is the same as that. The only thing you might have an issue with is the length and taper - if your current BIS bolts are tapered and you can complete at least 8 full turns when tightening the bolt they'll be fine.
Post by: bobblehead on February 10, 2010, 01:11:43 PM
i brought some alloy wheel bolts off ebay £18 for 20 ..... perfect correct size and cheap too .
so you can fit cinqucento alloys direct to a standard bis . and not have the worry they might fall off .
i know its been said you can use standard bolts, but for 18 quid, im alot happier now, as knowing my luck id have used standard bolts and my wheel would have come off ..
i asked him for : 26MM THREAD and a total length of 55.00mm long with a 17 or 19m heAD.. and thats what he sent
  .. and i paid using this item no: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220530204528
and voila ..... no probs atall  his user name on ebay was : thealloywheelshop
Post by: Fliplowe on February 12, 2010, 03:04:27 PM
Excellent, thanks for that information it's solid gold, I've just done the exact same thing and was looking for the correct bolts. Nice one!
The standard Bis bolts were definetly too short for mine, one of the wheels wouldn't even catch and 2 of the bolts just spun around uselessly Definetly not safe!
