Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: puck304 on November 20, 2009, 03:22:24 PM
Title: Aircooled choke cable
Post by: puck304 on November 20, 2009, 03:22:24 PM
 >:( Can anyone help! I'm having a right nightmare with choke cables. I'm on a 2nd one already, and they keep sticking or won't turn the choke on or off properly!!! Is there something I'm missing, apart from peace of mind....? Carb is new, by the way, and the choke itself works fine, just the cable!
I never had this problem with my previous aircooled.
Grrrrrr...... >:(
Title: Re: Aircooled choke cable
Post by: ChrisRLewis on November 20, 2009, 03:44:57 PM
the usual culprit is that the retaining screw for the outer cable is too tight, it's just got to be nipped very slightly.
(http://img231.imageshack.us/img231/230/choked.jpg)
Post by: puck304 on November 20, 2009, 03:57:31 PM
Aaaaaaahhhhhhhhhh! :) I'll give that a go, many thanks. I'll report back soon....
Post by: puck304 on November 20, 2009, 04:24:10 PM
No, it's not that, even if just barely finger tight. The choke will go on, but won't turn off fully, only half way. I had this problem with previous cable and outer sheath. I'm baffled, as it's only like a bicycle brake cable! Have to take it all apart again tomorrow and see if there's anything catching under the car. There isn't a difference with the same cable for a 500, by any chance?  ::)
Post by: Rusty's Uncle on November 20, 2009, 04:46:20 PM
That is a good point that Chris made I must remember that one. The set up is the same as the 500. Does the choke return OK when the cable is not connected because there is quite a strong return spring on the carb. Also is the inner cable connector at the carb end running freely in the actuating arm.  [-/
Post by: puck304 on November 21, 2009, 01:58:07 PM
I'm getting the right hump now. The choke spring is fine, when the cable is disconnected. It seems to be the cable. I've removed and replaced it a few times now, including the outer cable. I think that the inner cable's getting a couple of kinks or bends now, which isn't helping. When I operate the lever, the outer cable moves as well, when viewed from the inside of the car. I've tried the outer cable both sides of the lever as well. It just has a nipple on it which I assume just pushes into the hole on the lever. I know the inner cable just clips onto the lever. I'm thinking of handing this one over to a garage! >:( >:( >:(
