Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Funkin Go-nut on October 14, 2009, 06:47:07 PM
Title: Fuel leaking from carb and other problems...
Post by: Funkin Go-nut on October 14, 2009, 06:47:07 PM
I had the old girl up and running today, found out why it wouldnt start well or idle, both spark plugs were very loose.
anyhoo the car is clearly running rich as there is black smoke comming from the exhaust when you rev it up, but I noticed there is a lot of fuel comming out of the carb and filling the drip tray that sits beneath it..
Any ideas where its comming from?
The idle is a bit high at the moment but when you adjust it down the engine starts to die then stops all together when you rev the engine there is a brief stutter then it picks up (accompanied by a small black puff from the exhaust)
I am asuming this is due to over fuelling, where is this adjusted?
There is also a lot of oil all over the engine, what are the most common areas to check for leaks?
FGN
Title: Re: Fuel leaking from carb and other problems...
Post by: Funkin Go-nut on October 15, 2009, 06:30:07 PM
I dismantled the carb today and found that the float seemed to be reaching the top of the bowl, I'm guessing this is why the fuel was leaking out?
I have adjusted the float level, so hopefully that will be better. When I removed the float it seemed to have fluid in it, but there is no where for it to get in or out, is this normal?
The oil looks like it was comming from the rocker gasket after all, when I removed the cover to adjust the valve clearances there is a big noticible tear so it wasn't seated correctly leaving a space for oil to seep out, it also appears to have shrunk..
I did notice that the cover does not meet up with the cylinder head without the gasket, there is a 2-3mm gap is that right?
Iv'e got to wait for a new gasket before I can start it up and check that I have sorted the current issues, a friend lent me his colour tune kit, so hopefully that will help with setting the fuel/air mix.
Once the engine is sorted brakes will be next.
Post by: Rusty's Uncle on October 15, 2009, 06:49:46 PM
If you have got "fluid" in the float then it is knackered & that fluid will be petrol so don't try a blowlamp solder job. You could immerse the float in boiling water to spot the leak & evapourate the petrol then solder it with an iron. New floats are available from Webcon I am told. Cheap rocker box gaskets on eBay & they are about 4 mms thick so should seal OK . Over tightening of the rocker box nuts can depress the cover making the sealing more difficult.
Post by: bis13 on October 15, 2009, 07:59:29 PM
its nice to hear that the previous owner fitted the plugs and gaskets correctly before selling it ....oops
hope that the car gets better now you are getting it sorted.
Post by: Alex on October 16, 2009, 09:35:14 AM
Hi just had the same problem, and on advice bought a new float, 17 quid all in with delivery from webcon.
just a quick note of advice if you buy a Carburettor service kit be prepared to get a wrong shaped gasket for the carb, i've found this to be common practce with most parts i've ordered online, and now just cut new ones myself.
