Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Wee Red Motor on September 24, 2009, 10:02:22 PM
Hi all,
I have a 1991 Bis that's quite frankly taking the Bis.
Anybody any ideas as a simple fix for a worn choke mechanism on the Weber carb.
When the choke is applied the brass connector rod which closes the butterfly pops out of the hole in the lever.
This is no big deal as it usually relocates to above the lever meaning that when the choke is moved to the off position it pulls the lever down and opens the butterfly anyway.
The issue is that the next time the choke is needed the lever does not operate the butterfly.
It doesn't look as if there is meant to be clip holding it in place but maybe I'm wrong. I think that it just falls out due to wear.
Any suggestions would be welcomed.
