Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: cudhso on September 18, 2009, 12:32:46 PM
Hello,
I ordered a speedo cable from Axel gerstl for my BIS, which arrived in good time. Tried to fit it today, however it turns out the inner cable (the ony bit purchased) is about 15 to 20 cm too long. I can only assume someone has fitted a cable housing from a different model 126 in the past. Is the BIS speedo cable longer than other models, or has someone cut down the cable outer on my BIS?
I would sooner find the right part for my outer cable already fitted, rather than try to butcher the inner cable I have or remove the outer cable. Any advice would be wecome.
Richie
Thats a nuisance, sounds like it would be best to order a new outer. I didn't know they were different lengths, shame you hand to find out this way!
Thanks for replying!
I am about to heat a cable to see if I can shorten it and shape it into box-section as it enters the drive. I have a spare so what is the worst that can happen?
Cheers, Richie.
Here's hoping!
I could not do an aything with the inner cable :( . Replacing the outer seems likely to involve alot of pain & grief.
The one fitted is roughly 2.3m, whereas the spares which arrived are 2.51m. Any Ideas what the 2.3m cable is off? Maybe an X1/9? Maybe a 126 aircooled? If there are any kind souls out there who might know please reply.
Cheers,
Richie
At a guess I would think it was from a 500, theres about 10cm difference in length between that and the 126 which causes a pain with some cables.
The difference in length is 19.5cm, so it might not be from a 500. I shall order the outer shortly and have done.
Richie
