Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Rusty's Uncle on September 17, 2009, 06:29:48 PM
Title: EXHAUST ELBOW restoration
Post by: Rusty's Uncle on September 17, 2009, 06:29:48 PM
It is very difficult to keep the little cast iron exhaust elbows looking good & protected from corrosion. Has anybody had any joy with this ? Stuff like the heat resistent paint from Halfords does not last. I have been looking at high temp Stove Paint but not sure  :-
Title: Re: EXHAUST ELBOW restoration
Post by: ChrisRLewis on September 17, 2009, 07:09:14 PM
Have you tried VHT paint (Very High Temperature) this is supposed to be made for manifolds etc
Post by: Eklipze3k on September 17, 2009, 07:19:40 PM
Wait ... you've not been to the machine shop to see if you can have them remade in some super fancy high temp alloy? You, Sir, are slipping!
Post by: bardy on September 17, 2009, 08:24:29 PM
all my engine in my bis is coverd in that very high temp paint nd when we first started it up it startd smoking then stopd  but it gets mucky very easyily
Post by: bis13 on September 17, 2009, 10:38:29 PM
thats the problem with that paint it does smoke initially i wonder if its some sort of curing process? the only other thing i can think of is going mental and rubbing smooth and polishing then cleaning at regular intervals (like three times a day...lol)
Post by: prkahrvat on September 18, 2009, 12:32:25 AM
did you try with anticorrosive liquid taht can be bought in gas stations or something like that. you put part in that liquid and after that use very high temperature color
Post by: Rusty's Uncle on September 18, 2009, 06:36:43 AM
Not been to a machine shop but I did get a quote to have some vitreous enameled but it would have been about £25 to £30 apiece  :(
Hope to get something with a gloss finish so it looks & stays clean  [-/
Post by: gsxr126 on December 03, 2009, 03:34:41 AM
Hi Rusty,
I used a product called "nicoshine" on my polished alloy parts on my V8s. I treated my inlet manifold, rocker covers and heads in 2004 and havent had to touch them since. It stops polished alloy parts fading and getting that milky looking finish, so you dont have to clean them 3 times a day. Its pretty expensive though.
Post by: stuey on December 03, 2009, 08:17:45 AM
http://www.camcoat.u-net.com/ ?
Post by: Allan on June 12, 2010, 02:17:16 AM
What did Jaguar use on the exhausts fitted to the older XK engines. As I recall it was shiny black.
Allan
Post by: Darrell on June 12, 2010, 03:07:25 PM
Rusty, I thought you were going to get one of those fancy exhausts that bolt strait into the head, made out of stainless  [-/
Post by: Da Londo on April 15, 2012, 12:49:16 PM
Been to an oldtimer meet today and had a chat with a guy about the exhaust manifolds, he has a company that treats the manifolds with ceramic coating, they do this to reduce the temp around the engine, it would give some 33% less heat under the bonnet of a standard 4 cyl. The best thing is that it gives a really nice finish in some 14 colors. I asked about pricing and he showed me a small 4cyl manifold for which the cost would be 250 euro. So I guess for our little elbows it would be less. They also do self-adhesive alu patches coated with ceramic material for heat deflection. Check out the website at http://www.classiccarpartshelden.nl/Engels/home.html
