Fiat 126 Chat => Fiat 126 Chat => Topic started by: frubes on September 11, 2009, 07:36:39 AM
Title: Trip to Italy in a BIS
Post by: frubes on September 11, 2009, 07:36:39 AM
Hello all,
I am new to the site, I am picking up my 126 BIS tonight.
My plan is to drive to Italy for my Honeymoon and spend a couple of weeks pootling about Tuscany and the Lakes.
What are peoples advice for preparing the car for the road trip, beyond the obvious oil and filter? The trip is next year so I have plenty of time to run it in.
I've heard the Bis can blow head gaskets, is there a way to see if its on the way out. Normally I'd look for some white scum in the oil, but then its too late. Should I get the gsaket changed regardless just to be safe for the trip?
Cheers All.
Title: Re: Trip to Italy in a BIS
Post by: Gordan on September 11, 2009, 10:09:39 AM
Hello, and let me just say if you do go on this trip, it will be an adventure of a lifetime  [-/
Id personally recommend replacing the gasket cos there is no way to make sure its good, and try to find a copper one cos those never blow. than you have your standard stuff to take care of - brake system, wheels, suspension than fuelpump, carburetta, ignition, gearbox, clutch, cooling system (check and replace/remove thermostat), check the two stage fan switch... this is all the things i had to do during my 2 years of ownership, basically check and replace anything that can be broken  :oops:
Good luck
Post by: Rusty's Uncle on September 11, 2009, 12:03:12 PM
 :) Hi & welcome, I would say that if the car is on the road & half decent then just use it, get to know it and if all goes well put the car through a total service when you can. Cars like to be used and these little babies soon let you know when there is a problem .
That honeymoon thing sounds like a great idea as if you guys are still talking after a long trip in a confined space then the future will look good for you both  [-/
There are a few guys on here that could probably write a book on "ZEN - The Art of 2 Cylinder Motoring & Marriage Guidance"  </4
Good luck & best wishes.
**- Just Married
Post by: frubes on September 12, 2009, 08:14:17 AM
Well I got it back 100 miles from Bristol which was a start, but was anything other than an easy ride.
I picked it up in the dark so couldn't really see it, but for £350 it moved off and stopped so paid the man.
Got to the petrol station and the oil light comes on.... Open the cap, and shock horror it looks a bit milky in the filler pot. However I took a level with the dip stick and it seemed to have oil in, topped it up, light still on, so decided to soldier on. It hadnt exploded by the first motorway services so checked the level, wiped the milky stuff out of the filler and carried on the remaining 90 miles.
Anyway, looked this morning and no new milky deposit, so presume it was just condensation. It got home so presume faulty light or sender?
Its red and quite faded, any suggestions? T-Cut obviously
Also what are peoples feelings about chrome bumpers? Its a 1990 BIS and the bumpers have gone grey and don't look the best in any case. Do the chrome ones fit straight on the same holes? They are quite cheap arent they? Or could have no bumpers?
I'd love to put some minilites on it, but understand that the mini ones donit fit? Is there a cheap way round this, I dont want to spend more on the wheels than the car.
Post by: bis13 on September 12, 2009, 10:20:58 AM
to be honest if you are going to travel to italy i would keep the stock wheels on as they are a popular tyre size and will have less rolling resistance than wider tyres and will make for a more comfortable ride if you plan on pimping it abit then cinquecento alloys fit and can be picked up at most scrappies or on e bay for good affordable prices. is the connection to the oil sender good as they tend to suffer there as for chrome bumpers they fit the holes however can be a tad pricey i prefer to just remove the lot and be done with it after all its not a concourse car and a couple of little dents every now and then add to the charm. its funny you are planning your honeymoon in a 126 as me and my missus ran off to wales in a pink bis , got married and broke down in several interesting places on our honeymoon! if you are going to italy make sure you have a spare fuel pump and rod , a spare belt, water pipe repair kit , alternator bolts (sorry pete), and expect a lot of fun.
Post by: frubes on September 12, 2009, 12:07:16 PM
yeah im thinking no bumpers is the way forward. But how do people relocate the fog and reverse light and deal with illuminating the number plate? Might just paint the steels silver or black. Did that on my first car 10 years ago. Looked quite funny. Where can i get clear front indicators from? And could do with some seat covers. Plain black if poss? Its all a new world of fun
Post by: bis13 on September 12, 2009, 11:08:51 PM
when you remove the rear bumper and brackets you are left with two holes for the brackets use these to mount the reverse and fog lights its easy. seat covers are a pain as normal car seats are so much bigger than ours so its a case of getting some made up or plugging in the sewing machine , clear indicators come up on ebay and are on german e bay etc. oh if you need to illuminate the rear plate then get an aftermarket job like most classics have i have done this and works a treat.
Post by: frubes on September 13, 2009, 09:18:49 AM
I have been kicking around the forum and I noticed when i move off, if im not gentle with it or drop the clutch the it can judder. Fine in all other gears. Sounds like the same thing as Gordan and someone else. Did it turn out to be a gearbox problem? Someone suggested adjusting the clutch first? I take it the italians didnt have auto adjusting clutches then? Are the expensive to buy/fit a new clutch/ gearbox?
Post by: Darrell on September 16, 2009, 03:21:09 PM
Why dont we organise a trip to Italy?
3 or 4 cars would be good as back-up :oops:
Post by: defender90 on September 16, 2009, 10:11:05 PM
 Camping Trip??   :-)
Post by: Darrell on September 16, 2009, 10:22:21 PM
If we could assure good toilets and showers I'd get that past the wife [-/
Could be good [-/
Post by: prkahrvat on September 17, 2009, 12:30:40 AM
Italy is near, i could come too
Post by: defender90 on September 17, 2009, 10:28:13 PM
  My feet have started itching!
Post by: bis13 on September 17, 2009, 10:40:07 PM
tell you what i wouldnt mind doing a bit of belgium next year maybe we could sort out something?
Post by: Darrell on September 18, 2009, 11:42:21 PM
Had to get new plates for MOT so ordered them with the 'GB' emblem in anticipation...
I'm in, but will need to start thinking now about dates as wifey needs to book long in advance for leave as she works for NHS :oops:
Post by: landyman on September 20, 2009, 09:44:36 PM
italy is one hell of a drive in a normal car dont fancy it in a126 probably 36 hours hard driving across france before you get to explore italy itself.but would love to try belgium as a group tour i can get a ferry from rosyth only 20mins down the road from here more expensive than dover calais but saves 2000km drive in uk.also belgium is pretty flat good for small engined cars imagine some of the alpine passes hard slog uphill and suicidal downhill for those of us on drum brakes !!!! **- .:).so come on who fancys it low season if possible camping or b+b good belgium beer + a nice fruit based drink for the lady's maybe some chocolate to stop them whinging!! 8)
Post by: frubes on September 21, 2009, 10:48:35 AM
36 hours...? at 60 mph wouldnt that be over 2000 miles. Birmingham to lake Como is 900 miles according to google maps. I agree, not an easy drive but no pain no gain. I did Birmingham to Val D'ISere in the alpes in a day, given I was in an Audi A4.
Check out my before and after... 1 day of elbow grease, a screw driver and some polish.
Still need o ge these annoying little rubber bits off the side where the bumper was.
Post by: frubes on September 21, 2009, 11:00:36 AM
After
In terms of seats, if i want a very cheap upgrade, given the length of trip are their any options, i.e. cinq seats?
Post by: landyman on September 21, 2009, 02:30:04 PM
sorry i was putting in some sleep,fuel stops,food breaks. don't know how fast your 126 is but averaging 60mph is an optamistic figure.driving back from poland i found my estimated timings for each leg of the journey were miles out it does not take much to delay things roadworks,congestion,brakedowns and wrongturns/bad map reading/signage.I am not knocking your journey plans think its a great idea I took my wife on a whistle stop tour of france.belgium,luxembourg,germany,switzerland and back through france via paris for a weekend all in 10 days she had never been abroad before and really enjoyed it. point being that was in a normal car that could clear 100mph on the motorways and overtake with ease, our beloved boggdwellers (fiat 126's) are hard work on long journeys !.good luck with your plans you have my respect.my recent trip was from konin in poland to kinnesswood in my aircooled 2500km stayed in 1 hotel near berlin, journey took 51 hours very hard driving approx 11 hours of that was sleep.
Post by: Darrell on September 21, 2009, 09:48:19 PM
Frubes I put seicento seats in mine, not an easy fit and very snug.
Seat belts have become a pain as a result but the seats are 1000% more comfortable.
I agree Italy would be a hard slog so Belgium might be better but always wanted to go to Italy so I'm kind of torn between the two ideas :oops:
I've checked mine with the satnav and she'll sit at 60mph but not uphill :P
If only I had another 10hp!
I'm eyeing out the 700cc piston and pot kit on a few websites, wonder if a few simple mods would make the cars respectable up hills.
I been thinking bigger carb and bigger pistons?
Wish we could get a copy of the 5th gear mod  :oops:
Post by: frubes on September 21, 2009, 10:19:03 PM
What are your wheels off they are cool
Post by: Darrell on September 22, 2009, 05:44:35 PM
They are off e bay :oops:
Dont know what car they were from, the guy I bought them from said they were off a Lancia.
They had big tyres on them, I fitted the Cinquecento tyres as the rims are 5.5's
Only bother was they were too wide for the body so had a long uphill struggle of modifying wheel arches :-
