Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: mic on August 17, 2009, 09:28:52 PM
How hard/easy is it?! i know id need some more tubing to run under the car and have to cut a hole in the front for air, but is there anything already in place to bolt the radiator to or would i have to fabricate mounts for it?
cheers
I think you would have to fab mounts, I looked at this recently for a conversion i was doing, I reckon it might be possible to use the existing heater hoses to get the water around.
Have a ganders at this, bigger engine swap but has a couple of good photo's showing the radiator and pipes up front - in the for sale section:
http://club126uk.co.uk/smf/index.php?topic=3850.0
i reakon it shouldnt be too hard, i have a 'spare' front end which i could have welded on the inside a couple of standard radiator mounts and run the pipes under the bottom.
If i were to use the heater hoses what would i do in the engine bay? just run hose as it is but without the rad in the middle as it'll go thru the rad at the front?!
It was common with Hillman Imps, I did this conversion to my Imp. It's a great solution to cooling issues and eliminates the need for power sapping engine driven or electric fans except when in stationary traffic.
I did the job twice, first was a 'quick' attempt using pipes under the car, later I did it properly inside the car, which enabled the use of bigger pipework. I used a mixture of copper pipe (normal plumbing stuff, with solder joints, elbows etc. to take it under the rear seat) and flexible.
I must point out that having a pair of hot water pipes running along the floor did make a noticeable increase to the in car temperature.
I don't think there is much point though unless you get your 126 making more than about 50 horsepower.
