Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Kent126 on August 12, 2009, 05:10:02 PM
Title: Oil dripping
Post by: Kent126 on August 12, 2009, 05:10:02 PM
Guys,
   I drove to work yesterday and back which is a 50 mile round trip. Engine running really quiet but i noticed an oil patch on the floor after parking it up. On closer inspection there appears to be a small oil drip coming from the engine.
I have cleaned up the underneath of the engine and it appears to be coming from the top of the sump, where it looks like it is bolted on to something. Don't know much about these engines, so just wondering if anyone else has had this problem, or what it is likely to be? It only drips when the engine is warm.
Hopefully it'll be a cheap gasket, seal or something minor?
Any ideas?
Tom
Title: Re: Oil dripping
Post by: Dan_535 on August 17, 2009, 05:13:41 PM
Hi Tom, chances are it could be something very simple i.e the engine is filled with the wrong type of oil. oil type, grade and viscosity is CRITICAL to any type of aircooled engine as aircooled engines generally run at a much higher temperature to their water cooled cousins.
Chances are someone has previously filled the engine with the wrong type, modern multigrades (halford's, garages etc) are great for modern cars but the amount of detergents, fancy particles and other gunk in there can actually cause excessive wear and tear, ruin the sealing gaskets, piston rings etc in a classic aircooled engine. high temperatures combined with the wrong grade makes the oil too fluid and it finds its way out when its warm - by the sounds of it this is exactly what is happening as its only leaking when warm from the top, if you had a cracked sump then it would probably be lower down?
Best bet if your unsure of whats in there is to drain out the oil and fill up with a fresh litre or two of Morris' SAE40 classic engine oil or similar, needs to be a mono grade 15/40 ideally in any event for a 126.
Hope that might be a starting point anyway...
Dan
Post by: bis13 on August 17, 2009, 05:39:05 PM
this car was imported from poland and had been stored and not used for a long period of time my guess is that because of this the gaskets and seals get brittle and when are heated up after such a long time fail . firstly where is the oil coming from as it can be coming from the gearbox via the imput shaft seal and dripping into the clutch cover plate , or it could be the main sump gasket ( could need a nipping up ). or could be coming from the rear main bearing seal keep an eye on it and if its not too much then just drive untill it gets worse . have a good look under the car and post us some more clues and we shall nail it .
Post by: Paul632 on August 17, 2009, 10:39:29 PM
I've got oil drips from driveshafts and gearchange shaft on gearbox.
My sump bolts were ALL in need of tightening when I got my 126.That was done some months ago; but I'm sure I noticed a small weep of oil from sump joint recently.I think the normal vibration is constantly but slowly slackening all the sump joint bolts.If you think about it the threads of these are normally permanently bathing in  a certain amount of oil, so the spring washers have a very tough job keeping these babies tight, where they should be.
I can't believe how quick that magic six months goes between oil changes; it seems to be coming round quicker every time !
