Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: elbisto on August 02, 2009, 12:25:20 AM
Title: removing the thermostat on my bis
Post by: elbisto on August 02, 2009, 12:25:20 AM
Hi Folks
I have decided after replacing the head gasket on my bis to remove the thermostat, due the amount of posts on here advising to do just that, to prevent the overheating issue.
I was wondering if anyone can advise what steps i need to take in order to do this? How do I go about reconnecting everything once the thermostat is gone?
hope someone can help, every day is a school day for me with the bis
cheers
Title: Re: removing the thermostat on my bis
Post by: Gordan on August 02, 2009, 07:17:40 AM
Hy dude, removing the stat will deffinetly help your cooling, but it will not prevent another blown gasket, maybe postpone it. i havent done this myself but i think you just need to take the housing off, rip the thermostat out, and screw the housing back out...  [-/
if you need more help say so ill put up pics  :)
Post by: Amateb8 on November 16, 2009, 10:04:09 PM
I have a BIS and I am a bit worried about the issue of overheating. There appears to be a consensus that the thermostat is one of the reasons why the BIS overheats. I think there is a downside to removing the thermostat. Its job is to block the flow of coolant to the radiator until the engine has warmed up. When the engine is cold, no coolant flows through the engine. Once the engine reaches its operating temperature (generally about 200 degrees F, 95 degrees C), the thermostat opens. By letting the engine warm up as quickly as possible, the thermostat reduces engine wear, deposits and emissions. I am a bit paranoid and concerned about this, so I constantly watch the temperature gauge. If the thermostat is stuck closed it should not take long for the needle to reach the red zone even when the fan automatically switches on. Another cause of overheating is insufficient coolant level. The coolant levels should also be monitored closely. There should be a warning light in the instrument panel indicating insufficient coolant level. The odd thing with the 126 BIS, it has no coolant bottle (with a max. and min. indicator inscribed on the bottle) like other cars, so I am a bit unsure how to top up the car with coolant. When I take the cap off from the rear hatch (left side), do I simply fill the thing up to the brim with water?
Post by: Darrell on November 16, 2009, 10:15:15 PM
The BIS is known in my circle of mates as a 'kettle'.
The thermostat is on the sump side, not on the head side, daft idea as the head gets hotter than the sump.
Bear in mind they take a 'kettle's worth' of coolant, worry about the flow when it's cold, but you'll cook you head gasket, it's just a matter of time.
All this said, one should run it till hot and check the fan comes-on.
Post by: Amateb8 on November 16, 2009, 10:30:49 PM
I think will just have to keep an eye on the temperature guage and also occassionally test that the fan switches on automatically. On the coolant topic, do I fill the thing up to the brim i.e. up to top until it overflows? When the engine is cold of course.
Post by: ciaoflyer on November 18, 2009, 01:10:20 PM
No you don't fill it to the brim because it needs some expansion room!  What you do, it's stated in the handbook, is turn on the ignition so the warning light is on, then top up until it goes out.  Remember to squeeze the big coolent pipe to clear any air lock and then the light may come back on so add a little more unyil out!
Post by: Fifi on November 18, 2009, 06:58:44 PM
if you have problems with cooling the engine try my tricks ;) I had the similar problem but removing the thermostat didn't helped so much.
http://126p.no-ip.info/dzial.php?id=74397
the same in google translate: http://translate.google.com/translate?hl=pl&sl=pl&tl=en&u=http%3A%2F%2F126p.no-ip.info%2Fdzial.php%3Fid%3D74397
Post by: Amateb8 on November 18, 2009, 11:05:09 PM
Many thanks. I did not quite understand the instructions from the handbook but I see it now. Sorry, just to confirm, presumably the warning light you mentioned is the warning light for insufficient coolant. The coolant hose is the big hose that comes out from the top of the radiator. Again many thanks for your assistance.
Fifi, many thanks also. Your approach is worth looking into if I start to get persistent overheating problems. So far, the problem has not arisen. I will definitely take note for your advice for future reference.
Cheers!
Amateb8
Post by: ciaoflyer on November 19, 2009, 08:39:55 PM
Yes the little red light on the dash and the pipe is the one from the rad and it goes across the top of the engine!
You can buy a kit from Ricambio that moves the thermostat to the cylinder head, this makes it open sooner, I have one and it works a treat, only problem is it's expensive - £125.
Another tip is to leave the heater leavers on hot all the time as this aids cooling very well, it will get warm in the car but hey you can open a window!
Good luck, our Bis is great so stick with it!
Post by: Amateb8 on November 19, 2009, 09:19:44 PM
Many thanks. Do you know the name of the kit? I may be a worthwhile investment.
Post by: ciaoflyer on November 19, 2009, 10:05:02 PM
Best thing to do is call Ricambio and talk to them about it, they are very helpul and he will know what you are talking about!
Post by: timot on November 23, 2009, 11:32:19 AM
well i had a weekend of this. went to bring my Bis home. Had been stuck of my dads drive after blowing the head gasket on it hours after buying it. So head gasket fixed by his local garage i thought i'd go for the next leg of the journey to get it home. approx 100 miles. too kthe scenic route through forest of dean to avoid motorway.
20 miles down the road starts getting couple of bars on gauge from red zone so i stop. fan hasnt kicked in yet but it starts cooling down so i carry on. about another 5 miles and its up there again so i pull in to hear that now familar sound of boiling water.
worried head gasket gone again. but dont think it is. filled with water and opened bleeder on top of rad. turned it over and ran it. no water spurting out of water filler.
earthed out the fan so it runs all the time and carried on. did the whole journey with the temp gauge only a couple of times going up as far as 3 bars.
think i will fit a switch on the dash as the fan clearly not cutting in when it should.
fan pulls a bit lot of power though. will need some heavy duty switch. i think it was pulling 15amps.
got home just as low level coolant light came on and low level break fluid came on.
wanted to beat it with a big stick but i suppose it got me home in the end.
Post by: ciaoflyer on November 24, 2009, 09:18:53 PM
Fan is proberbly not working because you have a faulty fan two stage switch and it needs replacing.  Also check the fan fuse because this can blow.
Post by: timot on November 25, 2009, 09:48:10 AM
yes something is up like that.
do you know where the location of the 2 stage switch is?
fuses all fine.
thanks
Post by: stuey on November 25, 2009, 10:19:12 AM
I beleive its in the bottom left hand corner of the fan housing  (you can see it from under the car) it is just screwed into the housing and has a couple of wires on it....
Post by: Darrell on November 25, 2009, 12:15:37 PM
How many wires does the switch have on it?
Post by: stuey on November 25, 2009, 03:53:43 PM
tbh I cant remember how many wire it has might be 2 or 3- the cooling fan switching system has 2 switches iirc- the one to the right of the radiator is an on/off switch (this is the one acutually screwed into the radiator)  this then runs through the speed control switch (the afformentioned one in the bottom left of the shrowd) which then feeds/controls how much current is fed into into the cooling fan itself.
Post by: ciaoflyer on November 27, 2009, 12:00:29 PM
(http://i32.photobucket.com/albums/d18/ciaoflyer/Eng62.jpg)
Two stage switch is number 4 on the diagram.
Post by: Amateb8 on November 28, 2009, 11:18:50 PM
I looked it up at Axel Grestl. Could the part you are all referring to is the thermal circuit breaker for radiator fan motor?
Post by: Amateb8 on November 28, 2009, 11:22:06 PM
I looked up Axel Gerstl. Could the part you are all referring to is the Thermal circuit breaker for radiator fan motor (1987 to 1992)
Post by: ciaoflyer on November 29, 2009, 11:43:50 AM
That looks like it!
Post by: Amateb8 on November 29, 2009, 05:55:37 PM
Ciaoflyer,
Going back to relocating the thermostat to the cylinder head. Do you have a picture of your thermostat in its new location? I am asking because it may be something that I can perhaps try to relocate myself rather than buying the kit.
Many thanks,
Post by: ciaoflyer on November 29, 2009, 08:13:41 PM
Look at petes red Bis he has it fitted and it's here in the garage section
http://club126uk.co.uk/smf/index.php?action=garage;sa=view_vehicle;VID=4
(Hope you don't mind pete?)
