Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: rizlarizla on June 29, 2009, 05:50:47 PM
After taking the BIS to my mechanic friend to show me how to do a basic service on my 126 BIS...(since i had to remove an engine mount to do this - i was not confident to do on my own)
- we proceeded to change the plugs, air filter and oil and cleaned the centrifuge system also...all done easily...veryhappy
- then we came across a problem my Distributer seemed to be broken and could not be adjusted or insert new points , luckily i had a spare which we used instead.
So we tried to start the car - it did not work...eventually got it going - he adjusted the carbs and did the timing by lining up marks on front near base don marking on engine...and it started to run (after lots of 'popping' from carbs and exhaust - looked like trial and error to me)
Anyhows - we gave the car a test run up and down the road all seemed great - pulled much better and we could turn the car on and off without problem...fine tuned the carbs with a screwdriver before we tested and i drove home
So thought great stuff...now a quick run to see Uncle Rusty and get my alloys and brakes fitted next...but i was in for a surprise
A week later have tried to start the car - it would not start easily...in fact even with choke on it was struggling to fire up an drun....it turned over but just would refused to run...got it running in the end and whilst trying to drive it it kept popping thru teh exhaust and when i slowed down to stop it would cut out if i wasn't heavy withe the accelerator...
So can anyone tell the rookie, what the mistake was please..?
I think it might be timing...or will it be the carb knackered after the popping episodes...? or might it just be starter coil...?
Any idiots guides paper instructions./pitures would be helpful... ;)
Cheers all
like you said it could be a lot of things, it could be the high tension coil (after i replaced mine the engine starts 10 times better), it could be the carb (mixture is very inportant) it could be the condensor, the points (dont know how to set this and timing, my bro does it for me :oops: ) it could even be the fuel pump. anyways try sorting the timing and points gap, and then move on... [-/
Cheers Gordan
after checking a few of teh things - it was the Contacts - points needed to be set again...there was no gap!
Now starts perfectly...
Glad you sorted it out... [-/
Cheers Gordan
don't forget to recheck the timing after adjusting the points [-/
huh...?
errmmm..how do i do that then? can you elaborate for the non techincal of the group pls..? ;)
(how i set the contacts gap - i put car in first gear and pushed it forward - didn't move much...then opened up the disti and set the points gap...et voila...sorted - car started and ran)
:) Sounds good & does that mean that you might be swinging bye in the near future. I have all of the parts that can be assembled to take some pictures of how the Disc Brake Conversion goes together so we could still do the Ladybird Book on 126 Brake Conversions or maybe a movie , how about "Honey I Shrunk My Stopping Distance"
STOP
</4 </4 </4
huh...?
this may help you
http://fiat126clubuk.freepgs.com/bispoints.pdf
it's easy to set the points the main thing is to get the heel of the points on the highest part of the cam lobe (the spindle in the centre of the distributor)
you will also find it easier to use fourth gear for pushing.
Once the points have been set correctly you then do the ignition timing
