Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Dessie B on June 28, 2009, 09:44:10 PM
Title: wheel bearings
Post by: Dessie B on June 28, 2009, 09:44:10 PM
Hi Guys,
 wos wondering if any-one ever did their own front wheel bearings.
 I cant get the centre nut to stay put despite 3 attempts at securing. Just how tight should the nut be? I greased the bearing before fitting, used a centre punch to create a crease in the nut at the groove in the shaft, but the bugger still comes undone before I get 100 yards!
 ANY suggestions greatly appreciated,
 Thanks guys, Dessie.
Title: Re: wheel bearings
Post by: phelps8031 on June 29, 2009, 06:32:16 AM
I've never had bearings out of a 126, but if your using the same nut all the time then the locking device on the nut may be damaged and cause it to come loose, a new nut should be used every time.
hope this helps
Post by: Rusty's Uncle on June 29, 2009, 03:54:25 PM
Hi , looked at your post this morning & could not think of an answer but I think there are a couple of possibilities here, the nuts are left & right hand thread , if you force the wrong nut on the wrong side the thread will be stripped. Also the washer under the nut has a tab that picks up on the keyway so it will not turn or transmit any turning force to the nut. If that is screwed the it could cause problems. Haynes manual has the torque settings.  [-/
Post by: Maddog on June 30, 2009, 07:06:51 AM
I'm guessing you've missed out the tab washer, or as mentioned by dessie the tab has been ripped off ,  if the tab washer is fitted then it is impossible for the hub turning to loosen the nut.
Post by: markie on July 05, 2009, 01:59:00 PM
I've just done mine and I'm not wanting to sound patronising but once you have tightened the nut up you are locking it in place by denting the outer flange of the nut in using a hammer and a metal puch arnt you??  This stops the nut from turning freely but can be undone again when needed, this is why it is usually advised to repace the nut each time as you perminently damage the nut by locking it in place.
Post by: Dessie B on July 12, 2009, 10:10:15 PM
yeah new nut every time although a mechanic told me new nuts on an older car can be a couple of thou bigger and to use the original again.
 I have been tightening the nut and locking it by centre puchinching the outer flange, but found the wheel moved, (nut wasnt tight enough) without nut unscrewing. Back on the jack, retighten and locked, crushed the bearing. GRRR
