Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Jan-in-UK on June 21, 2009, 10:13:25 PM
Does anybody can answer this question please? Thank you.
wobble bolts will take up 2mm but you may have to watch out for offset on rims not made for fiats...
Wobbly/PCD correction bolts will allow you to fit 4x100 rims, all you really need to be aware of is the centre bore. If this is too big then you need spigot rings, too small and you either need hub adaptors or to get the wheel centres machined out. On the assumption that it is the same as most other FIAT's the centre bore SHOULD be 58mm.
Edit: And offset ofc ;)
Can somebody explain me OFFSET please? >:( I am not good in these english terms at all, in Poland I would undestand anything :D
Where I can get these Wobbley/PCD bolts???
My 903cc project is almost finished but now i desire myself some 4x100 wheels 8) always some complications...
Thank you for your kind help.
Offset is "ET" on the rim, wich means "Einpresstiefe":
http://www.audiclub-chemnitz.de/images/content/tuning/felgentuning4.jpg
Bolts in ebay:
http://cgi.ebay.de/Bimex-Versatzschrauben-Lochkreisaenderung-Radschrauben_W0QQitemZ180362814779QQcmdZViewItemQQptZRad_Reifenzubeh%C3%B6r?hash=item29fe76253b&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1229|240%3A1318|301%3A1|293%3A1|294%3A50
http://cgi.ebay.co.uk/PCD-WOBBLY-CORRECTIVE-BOLTS-M12-X-1-25-35MM-SET-OF-16_W0QQitemZ290317487584QQcmdZViewItemQQptZUK_Cars_Parts_Vehicles_Wheels_tyres_Trim_Nuts_ET?hash=item4398454de0&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1683|240%3A1318|301%3A1|293%3A1|294%3A50
Thanks a lot, it helped so much (To administrator: give them karma for it :D please). Well, do you think 101,60mm is too much for this woobley bolts????
Found one amazing but I am not sure. If it is too big will stay with 100mm.
PS: He he - I gave them - wasnt aware i can do that [-/ [-/ [-/ cheers guys.
101.6 is waaaay too much, if you're really desparate to go for them hub adaptors will be needed. Personally I would stick to 4x100 [-/
My dude bought a SWAP from Poland, with a Punto-engine and BMW-rims. These do-it-yourselfer are so hardcore, they didn't use PCDs. They took a metal file and widened the holes in the rims...I got heebie-jeebies when i realised, that i drove 180km/h with this scrap heaps, before i found out about the quality of Polish craft... :-X
Not funny at all. Some jerks are still there - to save some money thwy would do anything >:(
But trust me - loads of things is changing in Poland for better last years. Good craftsmans are avaliable - you just need to pay enough for them As same in Germany is it?
I had my 903 engine fitted by a simple and very enthusiatic youg lad in south Poland. Simple construction, simple solutions but done honestly and well. Effect? After 4 years or racing it still works superb. Just Maluch needs some refreshing as it has some dinks, scratches and other nice things on it :D
Just by teh way - what is the proper offset or fiat wheels? What is the widest size of rimms ant tires to go with maluch (I can extend wheel arches, itsn't a problem). Thanks.
Will rimms + tires 185/50/R14 fit to maluch??????
Offset and diameter is ok for 100%.
Jan
not without modifications .
Thank mate, what sort of modifications will be needed apart from widening wheel arches?
For those tires you'd need a speedo adjustment in Germany, because they are too big in dia. and the speedo shows 4% less than in fact.
I'd look for 175/50-13. Incidentally i'd only mount 12", because this is the one and only 126-size! But if i had to join another size, i'd choose 13".
http://cgi.ebay.de/Mangels-Chromfelgen-7-x-13-et-25-LK-4-x-100_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1229Q7c293Q3a2Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem35a2378a5eQQitemZ230354815582QQptZAutoQ5fFelgenQQsalenotsupported
http://cgi.ebay.de/Mattig-Sport-Stahlfelgen-SSF-7-x-13-et-175-50-R13-VW_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1229Q7c293Q3a2Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem3ef662ca28QQitemZ270421641768QQptZAutoQ5fFelgenQQsalenotsupported
Thanks Andi, these mangels wheel on German ebay are really superb. Well, I bought my 14" already and they are on the way. So I will try to fit them and than see how much I will have to adjust wheel arches. I can always re-sell it after, qutie rare on Ebay in this size. If I would adjust speedo (not a problem) what sort of modifications I would have to do?
So I did try it today and i thought maybe it is worth to post it for others as it answers some questions people might have.
My rimms came over from Poland, these are quite rare 14" size Borbet with Abarth hubs on it. Looks great and in almost new condition. Fabulous. So off course I tried to fit them on having in mind all answers you gave me. And what do we have?
1. All four wheel arches would have to be extended about 1 - 1.3 inch.
2. On rear (with factory size coils) they fit superb and I could easily use it (with arches extended).
3. On front tires are a little bit to wide :-X they are 185 and slightly wider than rimm itself. But it just blocks a little bit when fully turned to each side.
So my question is (after obviously I would extend arches) - is it possible to fit 175 or even 165 tires on 6J 14" wheels???? Maybe lower profile 40???
Does these tires excist - 175/40/14?? 165/50/14??
Looks great so I thought I could try to do something, there is just a little bit of more space needed and maybe without big modifications it would be ok. Please advice. Pictures below.
(http://img135.imagevenue.com/loc487/th_43204_1_122_487lo.jpg) (http://img135.imagevenue.com/img.php?image=43204_1_122_487lo.jpg)(http://img211.imagevenue.com/loc109/th_43208_2_122_109lo.jpg) (http://img211.imagevenue.com/img.php?image=43208_2_122_109lo.jpg)(http://img198.imagevenue.com/loc699/th_43210_3_122_699lo.jpg) (http://img198.imagevenue.com/img.php?image=43210_3_122_699lo.jpg)(http://img226.imagevenue.com/loc198/th_43216_4_122_198lo.jpg) (http://img226.imagevenue.com/img.php?image=43216_4_122_198lo.jpg)
(http://img262.imagevenue.com/loc490/th_43217_5_122_490lo.jpg) (http://img262.imagevenue.com/img.php?image=43217_5_122_490lo.jpg)(http://img103.imagevenue.com/loc27/th_43218_6_122_27lo.jpg) (http://img103.imagevenue.com/img.php?image=43218_6_122_27lo.jpg)(http://img206.imagevenue.com/loc96/th_43220_7_122_96lo.jpg) (http://img206.imagevenue.com/img.php?image=43220_7_122_96lo.jpg)
(http://img215.imagevenue.com/loc399/th_43221_100_2661_122_399lo.JPG) (http://img215.imagevenue.com/img.php?image=43221_100_2661_122_399lo.JPG)(http://img215.imagevenue.com/loc177/th_43225_100_2662_122_177lo.JPG) (http://img215.imagevenue.com/img.php?image=43225_100_2662_122_177lo.JPG)(http://img228.imagevenue.com/loc116/th_43227_100_2663_122_116lo.JPG) (http://img228.imagevenue.com/img.php?image=43227_100_2663_122_116lo.JPG)
(http://img270.imagevenue.com/loc553/th_43229_100_2664_122_553lo.JPG) (http://img270.imagevenue.com/img.php?image=43229_100_2664_122_553lo.JPG)(http://img174.imagevenue.com/loc951/th_43231_100_2665_122_951lo.JPG) (http://img174.imagevenue.com/img.php?image=43231_100_2665_122_951lo.JPG)(http://img169.imagevenue.com/loc870/th_43233_100_2666_122_870lo.JPG) (http://img169.imagevenue.com/img.php?image=43233_100_2666_122_870lo.JPG)
Closest in dia. would be 175/50-14, but here the speedo delays 2%. I found only one tire in this size:
http://www.reifen.com/tire/search.do?speedIndexGroupId=V&runOnFlatAndReinforcedOptionValid=1&tirePageno=0&tireId=10004590&priceCategoryId=&tireSizeId=175%2F50+R14&runOnFlat=0&directSearch=true&reinforced=0&tireTypes=PS%2COS&nextStep=6
Next would be 165/55-14. -3%!. One tire, too:
http://www.reifen.com/tire/search.do?speedIndexGroupId=V&runOnFlatAndReinforcedOptionValid=1&tirePageno=0&tireId=15018346&priceCategoryId=&tireSizeId=165%2F55+R14&runOnFlat=0&directSearch=true&reinforced=0&tireTypes=PS%2COS&nextStep=6
If I would find tyres like that - do you think Andi it will sort out the space problem?
Maybe would be easier to extend arches a little more and have some spacers??
Honestly: Those big tires look ugly on your nice car! A kind of off-road. Hummer or stuff like that. Xzibit-pimp-my-ride-style. They try on big wheels, too, and they fail: http://www.softpedia.com/screenshots/Unofficial-Pimp-My-Ride_1.png And it doens't help, if you reduce tire pressure, as shown... [-/
The problem is the 14". There's little to no choise in tires. You should choose one from the two above, and adjust the speedo. Better solution would have been 13".
13" Borbet go for 50,-Euro in Ebay. (set of four)
i think the 10" fiat 500 style racing wheels look the best i am thinking of sorting some out . they lower the car as well as making them quicker on pulling away/sprinting okay the top end suffers for it but then its not such a big deal.
14" alloys make for much trouble to fit and like andi says the tyre choice is very limited and expensive. another option is to go for the 12" wider steeleys and fit 12" streetlegal yoko trackday tyres for that stick to the floor racer look.
Yep, you all right brothers. Mine 14" looks lovely but not for my fiat. Already gone to Ebay :P
When sold will look up somenthing else, these mangels Andi showed me looks really tasty...
A set of like-new 6x13 Mattig SSF went today for about 80,- Euro. They are made in England by Weller Wheels.
Incredible Wolfrace:
http://cgi.ebay.de/Wolfracefelgen-13x5-5_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1229Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem35a2310eb5QQitemZ230354390709QQptZAutoQ5fFelgenQQsalenotsupported
Borrani:
http://cgi.ebay.de/Bourrani-CMR-6x13-Opel-BMW-VW_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1229Q7c293Q3a3Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem35a2484bb9QQitemZ230355913657QQptZAutoQ5fFelgenQQsalenotsupported
Classic ATS:
http://cgi.ebay.de/ATS-6036-6-x-13-ET-30-Classic-Opel-Polo-Corsa-Manta_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1229Q7c293Q3a6Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem27a98c4a49QQitemZ170348268105QQptZAutoQ5fFelgenQQsalenotsupported
Ok, choice was made - I want to have 13" what so ever. Iknow all about rimms not (tnak you all)
So please tell me, what is the biggest possible size of tyre for 13" - I want them to fit to my orange without modifications.
Is it possible? If yes, please give me the size and i will go on hunting Poland/UK/Germany. I would apreciate.
Those Wolfrace went for 27,49 Euro: http://cgi.ebay.de/Wolfracefelgen-13x5-5_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1229Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem35a2310eb5QQitemZ230354390709QQptZAutoQ5fFelgenQQsalenotsupported
Missed chance...
Next chance on 5,5x13" Borbet: http://cgi.ebay.de/4-Alufelgen-Borbet-mit-Bereifung_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1229Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem3353bf9facQQitemZ220448399276QQptZAutoQ5fKomplettrQc3Qa4derQQsalenotsupported
And this one doesn't know the difference between Borbet and ATS: http://cgi.ebay.de/Sommerreifen-Borbet-Alufelgen-auf-Pirelli-3000_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1229Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem35a251d92fQQitemZ230356539695QQptZAutoQ5fKomplettrQc3Qa4derQQsalenotsupported
To your question about maximum size: My dudes pickup has 7x13 with 20mm spacer on rear axle: http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=260442065688&viewitem=&sspagename=STRK%3AMEWAX%3AIT&salenotsupported
I found some nice ATS's here and there, 13" of course. But all of them have centre bore 57,1mm....
Is it ok? I thought someone here said it should be 58mm. Please advice.
57.1 is VW fitment, 58.1 is standard FIAT fitment. Can't imagine it'd cost too much to get them enlarged at a machine shop though
Does anybody know any place close to London/Slough/Maidenhead they could do it for me? Sorry but my limited knowledge of english doesn't allow me to find anything on internet. How to look for it? What should I type in searche engine?
you need to find a local engineering workshop.
if you want to know what sizes are actually available then check camskill
http://www.camskill.co.uk/products.php?plid=m4b0s0p0 (http://www.camskill.co.uk/products.php?plid=m4b0s0p0)
and for tyre size calculator
http://www.miata.net/garage/tirecalc.html (http://www.miata.net/garage/tirecalc.html)
the reason the car looks jacked up is due to the sidewall to arch gap ratio, if you fit a larger rim and lower profile tyre, then you need to lower the car or it looks stupid, yours looks particularly bad at the back due to the tyre being flat and the swingarm kicking under.
if you fit 5.5j rims then they are going to stick out a bit, unless you go for a larger offset, ET45 ish. but then they may rub on inner arch/swingarms. 165 tyres are the widest you will get under there without hammering out the arches, even then they may touch the arches over bumps.
If I had a car as original as yours then I'd stick with 155/65/13 on 5j rims ET32-35
There are plenty of Fiat/Alfa/lancia that will all fit, it would make life much easier :-)
I Bought these the other day.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=230352926444
At that price a refurb is worthy doing and they will still be cheap :-)
Jans car'd need some classic Cromodoras! http://cgi.ebay.co.uk/Fiat-Cromodora-Alloy-Wheels-Magnesium-124-500-132-CD5-9_W0QQitemZ160347572494QQcmdZViewItemQQptZUK_CarParts_Acc_Wheels_tyres_Trims_Car_Rims_ET?hash=item255575c90e&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1689|293%3A1|294%3A50
Yes! And I would even be interested but sent him 3 emails and NOTHING. I can't understand why selling on ebay anything people aren't geting in touch with customers. It is ridiculous and starts to annoy me every time when I try to buy something.
Once again confused in my search ???
Will 13" with 155/80 R13 tyres fit to my maluch???? 80 sounds a little bit to much or I am just in hysteria? :P :P
155/80 series on 13 is too tall for a 126
the stock size is 135/80/12, use the calculator to pick a tyre with a diameter as close to original as you desire, bearing in mind costs vary alot depending how popular the size is
Your great calculator has no 135! Use this german one, it also shows the difference of the speedo.
http://www.reifensuchmaschine.de/reifen_rechner/reifenrechner.htm
Thanks Andi and Mad. German one works better for me. Now it is easy - 13" with 165/55 R13 will be JUST FINE.
Speedo just 2%, all the rest looks fine.
