Fiat 126 Chat => Fiat 126 Chat => Topic started by: phreak97 on June 05, 2009, 02:14:50 AM
Tomorrow I'm driving half way across aaustralia, is there anything I should look out for? last time I drove that far in a niki we broke down alot.. I've changed the oil, adjusted the points, done the timing, valve clearances.. and thats about it.. is there much else?
Grease to the kingpins! And of course some parts in the trunk: Capacitors, contacts, spark plugs, a pair of those driveshaft-connectors, how are they called? I don't know the english word. V-belt, fuses, oil, breakfluid, canister of fuel, spring and clips for carb-linkage, one or better two FILLED!!! spare tires, shiftrod connector, gearbox gums, and the tools for fixing all these parts. Phantasy has no limits...
...different car... :D
:lol:
Breakdown cover, or lots of dollars for when roadside repair isn't possible and you need towed ;)
take what you think you need you know your car and what goes wrong with it by now , just make sure you have a load of gaffer tape , a small reel of electrical wire, some very strong string , some steel wire and "bushtucker man" as your passenger. enjoy your trip i am in envy that your drive will be a good adventure and good luck. ;)
And beware of the road trains! :o They don't notice your little cookie box...
Yeah, good luck dude, and snap a few pics on the way [-/
well we made it one way! we drove from adelaide to melbourne. driving home tomorrow.. some things that have happened:
the car started to lose ignition and judder about before dying, I thought the points had closed up, but it wasnt that so I just wiggled the wires around the coil etc and it seemed to fix it, done about 600kms since then. also my brakes were pretty worn before, one of my front shoes has now worn to metal and is grinding, hopefully it wont get far enough to pop the piston.. got spare drums and shoes at home though, I'm not too worried about trashing those. also today my ignition light wouldnt go off for a little while. once I revved it up a few times it eventually went out, I hope my brushes dont wear out any time soon.
also my front wheel bearings have started to make noise.. how loud do they get before they collapse?
they dont collapse for ages dont worry .
made it home!
1700km in 3 days, hows that?
it wasnt even the wheel bearing in the end, my speedo is starting to make noise again:( anyone got one for an aircooled with miles and kms on it?
Is it the speedo head itself or the cable making the noise? Because I had a disco that had a noisy speedo cable, i just used to put some light oil down every so often to keep it quiet.
I guess it could be the cable.. it was fixed for ages after i replaced the speedo though.. ill try lubricating it first
