Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: bis13 on April 28, 2009, 12:23:05 PM
i have an abarth type rocker cover and have fitted it to my engine , however i found that as soon as i ran the engine it started pushing oil through the vent pipe and half filled up my catch tank (not such a silly idea now).
the only reason i can see is that the splash guard inside the rocker cover is not doing a good enough job as it is a different design to the original or because the vent has a smaller diameter bore meaning somehow there is an increase in pressure . this is a very popular bolt on part that is used often so i wonder has anyone else had any problems such as mine?
i once had mounted such a cover, too, but not for a long time, as i came to the realization, that it was garbage. It has no ventilationsystem like the original one, and, as you mentioned, the pipe is smaller, which increases pressure inside the engine and causes leakage. Those covers are just looking good, not more. The best cover still is the original one.
can you not fit a bigger vent pipe?
well i did think about drilling the bore out to a bigger size but to be honest i cant really be bothered as its only "gucci" and not "go fast" as andi seems to have been down the same path
"gucci" could not look better... [-/
http://img16.imageshack.us/img16/2993/schieberad003.jpg
BTW: This mat on your 126 looks incredible good!
You should drill it out, they look cool. Failing that, i may be interested in buying it off you!
andi - Nice looking engine btw - did you custom make your engine casing, it looks really neat. Is there still a thermostat in there?
Took me ages to download the photo of the engine for some reason, but I have to say it looks great. Better than gucci!!! [-/
Have you got a video of it somewhere?
casing is powdered black, thermostat is right in place, why shouldn't it? Sorry, no video, i've no idea what should i film???
Got 3 sets of main jets yesterday, 'm gonna try to find a good setup today, then probably i could record a sound check :salute:
am i right in thinking that the fan/alternator housing and thermostat housing are from a panda 30?
only i have never seen a 126 with this shape of housings , i think its that what has confused some of us?
if thats the case where did you buy these as i cannot find anything about panda 30 engine cooling housings anywhere!
and the engine bay looks well pukka by the way!
I ment a video of how the engine sounds like ;) Do you know what sort of bhp it is producing?
Mick I found this pics of the Panda 30 engine. The housing and the fan set up is completely different. So I guess Andi`s are "custom" made...
http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&item=330320311142QQssPageNameZMERC_VI_RCRX_Pr4_PcY_BIN_IT&refitem=330320287359&itemcount=4&refwidgetloc=active_view_item&usedrule1=CrossSell_LogicX&refwidgettype=cross_promot_widget&_trksid=p284.m184&_trkparms=algo%3DCRX%26its%3DS%252BI%26itu%3DUCI%252BSI%26otn%3D4
looking at that engine brings me to this question ,what way does the engine turn? and has anyone stuck this complete powerplant into a 500 or 126?
I think the engine turns anticlockwise. So not sure if you could even use it with the Panda box in the 126, as it is front wheel drive. I`m confused now :oops:
I recently purchased a number of Fiat 500 / 126 items from a guy who had imported a 500 from Holland that had a 126 engine fitted . He modified the engine & one of the leftover parts was an original Fiat Air Filter assembly that bolted on to the top of the fan housing like the one in Andi's picture. Surplus to requirements I put it on eBay as a mystery item. I then got an e-mail from a guy in Italy identifying it as the type of Air Filter that was fitted to the 126 engine in German cars. I modified the listing & a guy in Austria bought it . The things I do for 99p ::)
The EU , what's that all about then ???
On a completely different tack, I bought some bits from a Croatian guy at the weekend. Had a great chat with him about Fiat cars . He told me that his ex had a Fiat 500 before & after the "troubles" Aparently the car was often used for target practice & was totaly riddled with bullet holes but still drove OK </8
Panda Engine turns left, as mentioned. Allthough all things on your island are on the wrong side, this engine really won't fit into our 126 ;D
My housings are from a very german issue: The square head-engine. This was specially build for us to avoid emission from a leak coming to the heating. This was neccesary for approval. Air for heating only comes from the cylinderhead, not from the gasketarea and the cylinders. Even the crankcase is a little different, to take the housing.
If you are looking for such a housing on german sites, you have to search for "Eckkopf". I just found one for a dude, who upgrades to Panda, too, but those housings are getting rare, and mostly they are broken from vibrations.
It does not fit 1:1, but it's easy to do. Only alternator-housing needs about half an hour of work, thermostat housing is ok.
That is a very useful information. Have done a quick search on German eBay, but couldn`t find anything :(
Is there any other easy way to modify the panels to fit the Panda head?
Seems like you have to buy a complete car, because there's no housing on the market right now...
http://suchen.mobile.de/fahrzeuge/showDetails.html?lang=de&id=102638168&pageNumber=2&scopeId=C&sortOption.sortBy=price.consumerGrossEuro&sortOption.sortOrder=ASCENDING&makeModelVariant1.makeId=8800&makeModelVariant1.modelId=4&makeModelVariant1.searchInFreetext=false&makeModelVariant2.searchInFreetext=false&makeModelVariant3.searchInFreetext=false&vehicleCategory=Car&segment=Car&siteId=GERMANY&negativeFeatures=EXPORT&damageUnrepaired=NO_DAMAGE_UNREPAIRED&export=NO_EXPORT&customerIdsAsString=&tabNumber=2
trust you germans to be difficult and demand a different layout! that airfilter housing looks very suspect to falling off! i am gutted now as i would have bought the tin off rusty had i known! thanks for the ad you posted however its written all in bosh talk :D if only i had listened to my german pals when i lived with them for two years all i learnt was to swear and eat sausage. [-/
Was that when you were in the Diplomatic Core Mick ??? :beer: </1
unlike most foreigners the germans have the talent to laugh at themselves just like us.. are great for fighting with just like us.. and the best point is they hate the french just like us... oh and i forgot they talk better english than us!!
