Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Dessie B on April 25, 2009, 02:22:07 PM
Hi guys,
I have slight problem with the installing of my starter cable. I'll explain. The cable is still intact, and connected at both ends. The problem is the outer slieve seems to have come adrift at the starter end, simulating a broken cable when i pull the lever in my air-cooled. There is a metal type thingy stiil attached, which looks like it might go in some-where and twist through 90 degrees to locate, but I cant find where it locate.Its no biggie as a piece of 2x1 is doing the the job, have tried Haynes and Autobooks manuals, but no joy.
Any-one any ideas?
Thanks in advance, Dessie.
Sorry I dont know how this part is located. Perhaps a kind member will have a peep on their 126?
I had a look through my manuals, nothing available. The only thing that I could find is a Fiat 500R pic which just shows the part.
(http://img407.imageshack.us/img407/2060/126starterf.jpg)
Thanks Chris,
Thats the bit alright, in its entirity, think I might have a problem. The piece still attached to the outer slieve looks like a bit of this.
that piece holds the cable on the heating tunnel have a look under the car and you will see a small slot/hole in the underside of the passenger compartment heating tunnel this piece slots in the hole and turns 90degrees to hold it in place it will then keep the cable taught so you can start it without the aid of a piece of wood.
be carefull make sure you disconnect the battery before you do this .
Sorry for the delay guys, turns out the air-tunnel is rotten. Have a second hand one coming from Poland.Will let ye know how I get on.
Thanks again, Dessie
Got a brand new Air-tunnel for 22 zloty.( A Coffee). Starter works fine now. [-/
