Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Eklipze3k on March 28, 2009, 02:51:44 PM
Title: Renewing accelerator and choke cable
Post by: Eklipze3k on March 28, 2009, 02:51:44 PM
Got new ones already but am not sure where to start - guessing it's mostly an under-car job so will need to acquire some axle stands. Also read somewhere that the accelerator cable is best pulled thru with the old but don't understand how that'll work with that big ring on the end of it?
Can anyone give this n00b a step-by-step guide please?  [-/
Title: Re: Renewing accelerator and choke cable
Post by: Gordan on March 28, 2009, 04:46:19 PM
ive done my choke cable recently. At first i thought of just replacing the cable, so i pulled it out and tried to push a new one in, it turned out that the black thing (not sure what u call it) that the cable goes into was messed up, so i pulled that out too, and just pushed the new cable with the black tube round it thru all the places the old one went thru,,, basically all u need is a lamp, some pliers, and something to lift the car up so you can get under. that and first check where the old cable goes thru, so you can re-trace it...  [-/
as for the accelerator - dont know  :P
Post by: Pete126 on March 28, 2009, 07:02:02 PM
The cable runs through the transmission tunnel to the back and then out through the rear bulkhead under the front of the rear seat, If the accelerator pedal is sticking first try lubing the accelerator bar.
Pull back the carpet under the pedals and you will see the accelerator bar goes through an outer bar that is welded on the floor and runs across to the transmission tunnel this can some times seize up and stick, spray down the ends with something like WD40. If that does'nt cure it slide the passenger seat out, undo all the self tappers holding the plastic trim on the tunnel and door kick strips  undo the seat belt bottom anchorages the one near the door and the other on the transmission tunnel, you can then pull the carpet back over the tunnel then you will see where it all goes, then its just a case of threading the new cable in :)
P.S. The choke cable runs down the tunnel as well.
Post by: Eklipze3k on March 28, 2009, 07:20:31 PM
The accelerator isn't sticking, but one of the many previous owner has put the most mighty of bodges in place which tbh scares the crap out of me every time I look at it ...
(http://www.fiatforum.com/attachment.php?attachmentid=57023&d=1233055488)
Yes, those really are wire connector blocks  :-X
The choke cable I guess is either snapped or has become disconnected so I figured I'd do them both while I was at it.
Cheers dudes!
Post by: Pete126 on March 28, 2009, 07:29:12 PM
 :yikes: I can see them putting the wire connectors on as a get you home fix, he must have known he was selling it to you LoL ;D
