Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: phreak97 on December 26, 2008, 03:11:23 PM
i first noticed when going up a hill with an 80km/h speed limit.. when i got to about 75 in third the car started to jerk a bit, it loses power for a moment here and there. since then i have adjusted the fuel mixture and the timing, but it didnt change anything.. after driving a bit the point where it starts acting up lowered to around 55 or 60km/h in third and it complained alot more, so i guess it either gets worse when it's hot, or it's just getting worse full stop.. i've only drivin it once for any length since it started doing this. also, it does it in all gears, it's just that third is the one where getting to high revs is actually useful, so i notice it most often in third.
at low revs i thought i could hear small backfires too, but im not 100% sure..
and here i was thinking niki'd been reliable for most of the year.
what should i try?
Fuel starvation ?
Fuel starvation.
Classic 126 fuel pump rod wear.
Replace the rod that runs the pump and try it again. ;)
Well you'll always hear small backfires (not large bursts), if it's got the 650E engine.
Hey!
I had this problem myself recently.. or just a really similar problem.
I thought initially it was just really bad spark plugs or bad timing, but it turned out i had a badly corroded wire supplying voltage to the ignition coil.. which means at low revs it was fine, but at high revs, it didnt have enough voltage to create a reliable spark.
Hope this fixes your problem.
(and i would suggest quickly trying this before the fuel pump rod.. because its not leaning out(weakening) at high revs, just missing and being jerky.. more an ignition sorta symptom than a lack of fuel symptom.)
Rob :)
it actually stopped doing it:P im sure itll start again though, thanks for the ideas, ill know a couple of things to check on when it starts it again.
what's a 650E engine? mine's a 650, but i dont know what the E is about..
some european exhaust bullsh*t, nothing a real 126 should worry about :P
haha:P
mine has a standard exhaust for a 650 motor.. it looks the same as a fiat 500 exhaust but apparently it's bent around the heater pipe differently or something so theyre not quite interchangeable..
i've never noticed backfiring before..
the point gap was too small.. i opened it up and the problem went away.. i was out at the time and just guessed, so i've gotta readjust it properly and do the timing, as it's pinging a bit now, but at least i found the problem.
