Fiat 126 Chat => Fiat 126 Chat => Topic started by: Darrell on December 22, 2008, 09:26:02 PM
1st gear died tonite.... :( :(
mines dead for a while now... i feel your pain... :(
why didnt they make these things out of titanium if they didnt want to synchronize it.. :-
Sorry to here that Darrell, are you going to buy a repair kit or l :( :( k for another gearbox
My 1st gear change is quite noisy unless I let the revs die. Is it part of the design? I notice it quite a bit at junctions and roundabouts if I try to get away quickly having just put in the clutch, there is a crruuunch.
there shouldnt be any sound when you go from 1st to 2nd, but if you try to go from 2nd to 1st while the car is moving youre going to end up in the "My box doesnt have a 1st gear" club, like myself and darrell :o
I try not to use 1st gear only on up hill starts, mine seems quite happy pulling away in 2nd :santa2:
thats the way.....my granddad refused to use first gear on the flat in any car..calling it 'crawler gear' hehehe.
the 126/500 box is an old school design,made when people knew how to drive them.......todays cars do not prepare people for 126/500/2CV style driving, i used to change down into first often on mine, just double de clutch (learnt that on a crash box'd bedford MW) ;)
but if you cant properly double de clutch, saty away from first gear as much as you can...the 126/500 will pull happily in 2nd from standstill with driver only (if not tuned to the max)
I wonder what your Driven plate has to say about this </4 :santa2: :D :P
a clutch is far easier to change than a first gear cluster...been there done that.....anyway the clutch shouldnt suffer,just let it out gently in second an off they roll......my buzz's 1/2 wouldnt because of the few little mods id made, but in stock trim the 650 is more than capable....
you can at least halve the usage of first doing this, i also used to choose my parking so as to limit reverse use..... ;)
yes, i now see what you mean...
I am thinking mine will be a 3 speed for a bit.
I have a BIS I have tried selling, nothing wrong with it but prices are down and in spares she'll be worth more than I can sell her for, to me anyhow.
Repair bits for the box are £119 on e bay, I could/might sell the BIS for 200...250 at a push.
With new king pins etc, wasted coil, intermittant wipers etc I could pull across to my air cooled.
Doesnt make sense and I'd hate to see the BIS end up like this but hey ho needs must.
If the gearbox is O.K. in the bis Just swop the bellhousing over and fit the bis box.
Yeah this will be BIS box No2....
Maybe I am just a savage and should forget the use of 1st gear for good..
Only you can answer that Darrell :D :D :D But to everyone else if you've got 1st and reverse look after them, they don't make gearboxes like they used to. Thank God [-/
