Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: custardboy on November 21, 2008, 08:10:35 AM
Can anyone offer some advice with a common problem!
My 126 aircooled starts first time every time from cold but as of Monday will not restart once it has warmed up. It turns over no problem but no amount of cranking will get it to start. If however, it is left to properly cool down for say an hour it fires into life without the starter having to hardly turn.
The thermostat is working fine.
I cannot stop anywhere on route for fear of it not restarting. It does seem to be running rich as well.
I have looked through all the threads and found various similarities but nothing the same.
Some seem to suggest the points may be closing up as it gets hot does this sound plausible or could it be coil related?
Custardboy
this is just a guess, id check the fuelpump if i were you, my old one used to stop working once heated up.... just take the pipe that goes to the carb from the pump and have someone turn it over a few times, if you get splashed, im wrong... :P good lukc
when you start up when hot do you start with your foot on the clutch? and if the car wont start press the throttle pedal? without the choke. is the car pinking at all when running under load?
if the fuel mixture is too rich it can cause this, when mine's hot, if i pull the choke up the car wont start (this is normal). does your choke work properly? (does it change the engine revs at idle?). also might be worth adjusting the fuel mixture.. with the engine running and already hot (and choke lever down), screw the mixture screw in until the idle starts to drop, then turn it back one revolution. it's probably not the most precise way of adjusting it, but it's roughly in the right spot then, and you can rule out fuel mixture if it still does it.
might be fuel vapourisation check your fuel pipes are well sheilded from any thing hot.
Thanks for all the suggestions, I think I may have found the fault which is the condensor, though will only know when I am brave enough to go somewhere.
I have a few electrical problems which I think collectively are not helping my 126!
Thanks again.
You have to re-set the valve clearances (hope that's how it's called in English).
Probably you were doing something to the cylinder head - when the engine is hot the valves won't open.
Well I don't think the hot starting problem was necessarily related but on Sunday whilst driving on the motorway the engine started to make a funny noise and I have lost compression so think the head gasket has blown. Won't start at all now. Going to remove the engine and strip it down to see whats what. Thanks for the advice so far.
let us know how you go!
edit:
oh right, just saw the other thread:P
