Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: nathan126 on October 02, 2008, 04:57:49 PM
Hey all,
Yesterday driving into a carpark to pick up my brother my BIS wouldn't restart, just the noise of struggling to turn over..
I've checked the alternator/belt and recharged the battery and now it starts in the dry. I guess the heavy rain caused it to short out somewhere.. draining the battery.. just wondering what points you'd all suggest to look into? i don't want this to keep happening, especially in winter
:sad:
This happened to me too... it turned out to be those connectors on the spark plugs, and on the other side of the wire (corroded so badly they just werent there anymore...) (im talking about the wire that conects the sparkplugs and some thingy - my English stops here sadly... :shock: )
Thanks for the reply gordan, it can't be that with mine.. there's no problem with corrosion near the plugs. It's definately an earthing problem somewhere.. i just don't know where to start :roll:
Have anyone else had problems of this sort?
Started fine again today, also in the dry.. but thinking ahead i'd rather fix the problem now :???:
I had a similar problem on my air-cooled last winter. I ended up tidying up all the earths. Starting with the battery negative terminal to earth, then both connections on the power to starter cable, engine etc. It ended up working fine after that, so the problem was there somewhere. I think the starter is the main area where a short is likely to occur and sap the battery.
So is the battery only getting flat overnight?
Nope, it happened after about a 3 mile journey.. pulled into the carpark and turned her off. Went to turn over 5 minutes later and there was hardly any power from the battery.. ended up push starting. Apparently the indicators even started getting slower over the journey.. so there's a big power drain somewhere..
I'll try all the connections on the starter like Dom said, and have a hunt round earthing cables.. so far that sounds the most likely cause. I admit it is a little dirty down there at the moment..
It's been okay today, but when the rain comes it could happen again :???:
Turns out it is the alternator after all, it's not reading a thing now..
anyone know where i can get another at a good price? :???:
http://cgi.ebay.co.uk/A722-Fiat-126-Regata-Strada-Tipo-Uno-1981-95-Alternator_W0QQitemZ320009597685QQcmdZViewItem?hash=item320009597685&_trkparms=72%3A1345%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Cheers mate, i found one for a similar price on another site.. went with that in the end :D
