Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: elbisto on September 19, 2008, 09:18:27 PM
hi all
just a quicky question,
does anyone know what the best way to remove the choke cable is on the bis. Ive got a knackered one in my runner, and a good un in my spares car and just want to swap them over.
Ive removed the choke lever and released the cable, and with a bit of pulling from the back have managed to make it dissappear!pushing it back through doesnt seem to be helping, i just cant see it.
anyway, assuming I can find it, is the best thing to slip the outer off , or even leave it on, and just pull it from the back? I seem to recall that theres a little bracket that holds all cable outers to the body underneath, if i release that will it just pull through?
or will the nipple on the end of the cable get stuck on the conduit?
If that is the case, then i would pull the outer off at the back , end then pull it out through the lever hole, but how would i get the new one in through the conduit (assuming there is one)?
I know i should investigate further but I thought id ask first, save myself some headaches.
