Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: kerry on September 02, 2008, 07:29:37 PM
any ideas what might be causing it? It seems to be worse under load (ie more people inside) and/or uphill.
i tried topping up the oil as it was a bit low, and spraying WD in the dizzy, but neither seems to have helped.
any thoughts appreciated. :D
hi Kerry,
I'm no expert on BIS's(aircooled baby :D ) but the usual checks for misfire and poor running under heavy load for any car would be the basic points of a good service,
spark plugs worn,
old HT leads,
points worn/badly set and poorly condenser,
possible overheating, so fluid levels and coolant/radaitor flush,
or running weak due to,
fuel filter blocked,
carb gummed up or worn, either rebuild or replace as 126 carbs are cheap,
fuel pump worn or fuel lines/tank breather blocked,
timing needs set(@ BIS owners, does BIS have vacuum advance mechanism?) if so it may be fooked
other things to check would be battery and engine earth straps, electrical connectors on coil etc.
also a rusted out or blowing exhaust will cause loss of power under heavy load. check winter/ cold running air intake flap(if BIS has one) is working and air filter although these tend to cause over rich bogging rather than misfire.
after that your into a worn engine, rings and valves etc, but plugs, points and carb etc are favourite causes of poor running.
hope this helps,
Richie
:D
