Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: subvert73 on June 08, 2008, 09:55:18 AM
I just upgraded my 1978 model from adjustable strap type seat belts to inertia reel type, here's how to go about it.
What you will need - Flat bladed screwdriver (or something similar to prise off the plastic bolt caps), Ratchet with 17mm socket, 17mm open ended spanner, Stanley knife, a vice & a rubber mallet.
You will also require a set of inertia reel seat belts, If you can, try to keep all the bolts & fixings when you remove them, they may come in useful. I got mine for a tenner from a Polish Cinquecento that I found in a scrapyard.
First thing to do is remove the clasp end (the part near the handbrake) of the original belt from your car, make sure you remove, but keep, the right angle bracket that attaches this part to the floor as you will need it later to fit the new belts. I have circled the bracket in this photo.
(http://club126uk.co.uk/forum/userpix/592_right_angle_bracket_1.jpg)
The inertia type clasp will need some modification using the vice and rubber mallet. You basically need to bend the shaft so that it will bolt straight down to the hole in the floor that the right angle bracket was attached to.
Before modification -
(http://club126uk.co.uk/forum/userpix/592_orig_clasp_1.jpg)
After modification -
(http://club126uk.co.uk/forum/userpix/592_clasp_modded_1.jpg)
Fitted -
(http://club126uk.co.uk/forum/userpix/592_new_clasp_1.jpg)
Next remove the original strap part of the seat belt from your car. To get to the bolt at the top of the strap you need to push the plastic cover upwards to remove it.
(http://club126uk.co.uk/forum/userpix/592_top_bolt_1.jpg)
There are only 2 fixing points for the original strap but he new strap needs 3 fixing points. Don't worry you wont need to drill any holes into your beloved motor, this is where you use the bracket that you saved earlier.
At the floor fixing point use the longest bolt you have to bolt down the right angle bracket and the bottom end of the strap (as in the photo).
(http://club126uk.co.uk/forum/userpix/592_bottom_anchors_1.jpg)
You may need to be a bit patient with this as there is not much room. I found that the passenger side fitted easily but on the drivers side I had to use the knife to cut away part of the soundproofing behind the carpet to make room.
Next fit the top fixing to the hole at the top of the B pillar. Sorry about the poor photo.
(http://club126uk.co.uk/forum/userpix/592_b_pillar_1.jpg)
Then carefully pull the reel down and attach it through the hole at the top of the bracket. You will need to use a spanner because of the restricted space.
(http://club126uk.co.uk/forum/userpix/592_reel_attached_1.jpg)
That's it, all done. You may prefer to find, or make another pair of right angle brackets so that you can still use 1 pair at the clasp end. The clasps would fit better if you did.
Here are some photos of the new belts fitted -
(http://club126uk.co.uk/forum/userpix/592_full_finished_1.jpg)
(http://club126uk.co.uk/forum/userpix/592_bottom_finished_1.jpg)
Best of luck, Steve.
Just red your thread steve, and i must say thats some clever thinking, but i have a suggestion...
My bis has those inertia seatbelts, so you could have copied the orig, just to save that little bit of passanger space...
You could have just cut a hole in the back handrests or whatever its called ->
(http://club126uk.co.uk/forum/userpix/559_592_full_finished_1_1.jpg)
(http://club126uk.co.uk/forum/userpix/559_DSC05066_1.jpg)
and have it looking like this, i think the mechanism would fit perfectly in there...
Just a thought there, but your version looks just as good... :)
Hi Gordan,
I'll have to take a look behind that panel to see if thers's a mounting hole there.
Cheers, Steve. :D
Should be, just be careful not to brake those plastic things that hold it to the car, they tend to crack easiliy... :wink:
the bolt holes will be there i did the change on my car but bolted them into the side as cro stated. either way it works so good on you fella.
