Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Gordan on May 06, 2008, 01:22:06 PM
Title: Disc brake conversion, is it worth it?
Post by: Gordan on May 06, 2008, 01:22:06 PM
Im just wondering if all the money and time spent into converting drum brakes to disc brakes is worth it? The car doesnt have servo asisted brakes, so its equally difficult to push the pedal one way or the other. so what do the disc brakes offer that drums dont (on the 126, not in general :)) I have changed all the replacable parts on my drum brake system, and she brakes and stops like a charm...
all info and opinions are welcome. Thanx.
Gordan.
Post by: Gadge on May 07, 2008, 05:44:23 PM
the disc setup is a far superior way of braking than the drum sort, they offer better cooling of the friction material ( a big weakness of drums is they overheat ) their also easyer to maintain ( less moving parts ) and a pair of pads "squeeing" a rotating disc is more efficient at stopping than two shoes expanding........their just better  :D
Post by: Gordan on May 07, 2008, 06:33:47 PM
Cheers mate, thx for your reply. But all that you said is bassically general knowledge, but im interested apart from the heat factor, what do they offer to a car like the 126. I know that disc brakes are supperiour to drums, and that is why wee see them on the modern cars and not drums, but you go through all the trouble buying these sets, making them work, and worrying if theyre set up correctly all the time, and you still have to put 2 tons of pressure ( :D ) on the pedal, and you stop in the same distance as a drum braked 126. (I can block my wheels with no prob)...
This is why i asked the question in the first place, just trying to get informed if its worth it, so i might put it on my bis one day..
Cheers. Gordan
Post by: Maddog on May 07, 2008, 09:51:05 PM
nothing wrong with the stock drums on a stock engined car, after all they only have to reign in a 600kg car with 26 or 30 BHP. as long as they are in good working order then why change them
Post by: Darrell on May 09, 2008, 10:33:53 AM
There have been days where I come off the motorway doing 80 and the traffic sortof slows down very quickly...that is when I wish I had discs!
Suppose I shouldnt be doing 80 but then I suppose I shouldn't do alot of things  :cool:
Post by: hudsonhenry on May 10, 2008, 09:10:11 AM
A lot of race cars have a non servo disk brake set-up, they get the power of disk brakes, but removing the servo gives more feel at the pedal.
Ok so you have to push harder with no servo but given the same pedal pressure with a disk brake set-up against drum brakes the disks will always stop shorter.
Post by: rockchevy85 on May 19, 2008, 11:29:49 PM
Quote from: hudsonhenry
Quote
Not only do you get more feel, but in terms of racing a servo-assisted brake has a noticible delay before disengaging after the pedal is released, as opposed to a non-servo which releases instantly.
Post by: phreak97 on May 23, 2008, 03:27:12 AM
i dont see the point, one of the things i love about my niki is the shorter stopping distance over my other cars, and i'm on stock brakes..
why fix something that isnt broken?
on the other hand, my morris 1100 has discs on the front from the factory, and it's a b******* to stop..
Post by: Gordan on May 23, 2008, 12:06:25 PM
It has shorter stopping distance?? What other cars do you have? a ford model T  :?:  :D  I have to drive at least a few meters behind the car in front of me just to be able to stop behind him, not on him  :lol:
and my whole brake system is brand new (well, only the pipework is orig... )
Post by: phreak97 on May 23, 2008, 01:07:52 PM
morris 1100 s, cm valiant (chrysler regal), fiat topolino, and a mitsubishi sigma, though that possibly stops quicker.
Post by: Gordan on May 23, 2008, 01:41:33 PM
well, the 126 is probably more advanced than most of your cars, but compared to todays cars, it stops from 100km/h in what 100 m?  :D
Post by: phreak97 on May 23, 2008, 11:36:39 PM
well i dunno.. i could lock up the brakes if i wanted.. so shouldnt the stopping distance only be limited by how hard you push the pedal?
Post by: Gordan on May 24, 2008, 12:10:27 AM
yeah, i thought so too, thats why i started the topic, but it turns out no...
Post by: Pete126 on May 24, 2008, 01:04:37 AM
It all depends on where you live and how you drive, the drum setup is quite adequat for normal town driving the only problem is when you have to stop quickly from motorway speeds or long downhill sections in traffic where you have to use the brakes constantly, the drums and linings get hot and you loose braking due to brake fade the heat also transfers to the brake fluid which can boil. where as discs don't fade in normal use and cool down quicker, so they are safer.
Post by: Darrell on May 26, 2008, 08:14:19 PM
Yeah I do alot of motorway driving (when it is on the road) and as I said before I have done alot of praying.
There have been days I get cocky and close down the gap to an acceptable gap for modern cars, the traffic comes to a hault so I slam on brakes and the car violently swerves from side to side.
Somehow it has always stopped just in time with the occasional close-up's of the boot lid of the car in front.
I plan to do the following:
Disc brakes
Braided hoses
Higher DOT rating fluid and toying with the idea of a servo but then see how it goes with the discs etc.
I figure a 126 is never going to be a speed demon so might as well make it handle like on rails and stop very quick.
Post by: Gordan on May 26, 2008, 10:35:08 PM
Quote from: "Darrell"
This happened to me twice, so i decided not to go fast ever again... :???:
Post by: phreak97 on May 27, 2008, 12:35:17 AM
we dont have motorways as such, so it's hard to compare.. but on the few occasions where i've had to stop quickly my car has never swerved at all.. perhaps your stock brakes are not all that happy? mine's only 18 years old afterall.
if you want a scary experience, drive a topolino on original specification tyres like mine (very thin, and made from hard rubber) the wheels lock and the car keeps going.. last time i took it out, approaching an intersection the lights went orange, i was too far away to reach it before it was red, with plenty of distance to stop (i thought) but i ended up screeching to a stop just over the line anyway.. i think im going to have to get it looked at by a professional. lol
thats the other thing.. i have all new tyres, i think theyre probably a big factor, theyre also 135sr12's like it says in my book, i dont suppose any of you have those anymore.. they'd reduce the torque required from the brakes, being smaller.
Post by: Gordan on May 27, 2008, 05:13:44 AM
Mines 17 years old, new brakes, new tyres (135/70 13) and this happened when i was doing 80km/h downhill, the traffic stopped unexpectedly, so i started to brake, my front end went straight, but my rear end went left-right-left-right, and i managed to stop a few cm from the car in front....  :???:  (scared the living jesus out of me)
On the other hand, it was really funny watching the dude behind me drive at a distance of 10 m for the rest of the trip...  :lol:
Post by: phreak97 on May 27, 2008, 09:53:19 AM
wow.. i wonder what caused that.. it sounds pretty unusual.. try jacking up the back and checking for slack in the bearings (grab the wheel and wiggle it up and down) there could be something more than just your brakes at fault there..
Post by: Gordan on May 27, 2008, 11:44:50 AM
DK, but i aint messing with it any more, it drives just fine now at city speeds, stops like it should, and i figure why mess with it? I have no intention of driving fast anyway, since this could happen:
40 km/h:
(http://img143.imageshack.us/img143/554/crasch1qh8.gif) (http://imageshack.us)
S C A R R Y!  :smt119
Post by: phreak97 on June 11, 2008, 03:15:44 PM
having said disc brakes probably arent worth the money, i've got some news.
a guy i know is moving house and has been clearing out a shed full of 500 and 126 bits and has given me alot of stuff (a couple of carloads!) for free, today he gave me a used disc brake kit for free!
guess ill be finding out first hand if theyre worth it or not. they do need a rebuild, but it shouldnt be a problem.
Post by: subvert73 on June 11, 2008, 04:03:25 PM
Quote from: "Cro_126Bis"
I used to have a 1975 Mini that did the same thing, in fact on two occasions it actually spun through 180 degrees, very scary on a public road.
It's caused by the fact that during heavy braking the weight of the car shifts towards the front. Therefore there's less weight on the rear wheels so they lock up before the front ones. You're effectively doing the same as pulling up the handbrake so any slight turn on the steering wheel under heavy braking will have the same effect as a handbrake turn.
Rover cured this problem on the Mini by fitting an automatic brake bias unit. If you braked heavily the force shifting to the front caused a ball bearing to run up a ramp which partially shut off the brake fluid to the rear. This in turn caused both front and back wheels to lock up at more or less the same time.
This won't be so much of a problem on a 126, as being rear engined there is more weight on the rear wheels straight away. However I should think that wouldn't make much difference under heavy braking whilst traveling fast, down a hill on a wet road.
Fitting disc brakes to the front of a 126 will have a similar effect to fitting a brake bias unit such as I just mentioned. The front brakes will lock up before the rear in normal braking situations, but under heavy braking when there is more weight on the front they should lock up at a similar time.
This is one very good reason that disc brakes are better than drums.
Post by: Gordan on June 11, 2008, 04:04:04 PM
:smt023
Post by: phreak97 on June 11, 2008, 04:22:29 PM
i guess in this situation, but if you went and installed discs all round you'd be right back where you started, only quicker:P
Post by: dajwid on June 17, 2008, 08:04:45 PM
Had a 126 on discs, very agressive for road use, they were on or off, no feel at all. I only had them on the front and you could get the back 2 wheels off the ground. Fun at the lights but the novelty soon wore off.
