Fiat 126 Chat => Fiat 126 Chat => Topic started by: jon.hunt on April 12, 2008, 04:15:07 PM
Title: Cav-Mac
Post by: jon.hunt on April 12, 2008, 04:15:07 PM
Hi all
        I'm using a Cav-Mac  Rocker Cover and I'm on my 3rd, one now, Just cannot stop them Leaking Oil at the Cylinder Head Joint, Anyone Else have this Problem, as the Hot Oil Burning Stinks real Bad.
                                                      Jon.
Title: Cav-Mac
Post by: bis13 on April 14, 2008, 11:33:40 AM
what is a cav mac ? the only problem you will get normally with a rocker cover is if you overtighten the bolts and distort the gasket then you will lose oil . you can use gasket sealer and fix directly to the cover and bin the gasket ( i have ) with no problems . also have you used firous washers under the washers and nuts ?
