Fiat 126 Chat => Fiat 126 Chat => Topic started by: Normansinjunstevas on February 08, 2008, 10:32:54 AM
Hello.
Is the Big-End bearing replacement a pain in the backside with the engine insitu? The Haynes Manual states that it's an insitu job, but then proceeds to whip the engine out of the car.
Are there any members who may be able to point me in the right direction with regards to the parts which should be replaced, and how many knuckles are likely to be bloodied?
Thankyou
Norms
TOP TIP; if you wish to work on the engine take it out of the car . it is so much easier to do work on it in a nice warm garage/workshop . as for knuckle damage it depends on how you work in general.
Cheers bis13.
Was your first engine-out a real ordeal, or a piece of papyrus? I only ask because I used to shift Moggie engines well quick, once practiced. Haynes don't give you much idea of the real level of difficulty or how long it is likely to take.
Do you need girt, manly trolley jacks like the ones you find at Kwik-Fit, or will a poxy little do the trick.
Sorry for all the silly questions, but I 'm a bit new to these little cars, so any advice you can give me will be greatly appreciated.
Respect.....Norman
Hi Norman.
If your used to taking moggie engines out you won't have a problem with this one, should take 1 to 2 hours just depends on how tight and rusty the bolts are on the engine and backpanel, no special tools needed.
Cheers Pedro,
Regards....Norman
Mate, removing the engine is actually very easy... I took mine out a few weeks back, and had no problems at all, (this being the first time i removed an engine ever... :cool: ) and I even managed to put it back in and make it work again.... :D , the only thing I can warn U about are the 4 screws that hold the rear valance to the car, cos one of mine broke while I was putting it back in, and I red that someone else also had problems with them... other than that u should be fine.
(http://club126uk.co.uk/forum/userpix/559_gh_1.jpg)
(p.s. i found it useful to stick a little note on every vire and pipe before removal, just to make re-assembly easier)
{(we are talking about a BIS right.. :?: ..)}
Cheers Cro.
That's reassuring to know. Mines an aircooled, which looks a bit easier to me, due to lack of pipework.
At least I don't need to fear removing my engine.
Regards.....Norman
Oh, DK much about aircooled ones, hope its easy..
The name is Gordan by the way...
p.s. nice to see a aircooled owner joining, ads diversity to the forum....
cheers :smt041
whipping out the aircooled engine is so much easier than the bis , dont work on it in the car as a nice bench and a mug of coffee in a warm garage/workshop is so more appealing than on the floor bent over in the engine bay nutting greasy metal every five seconds !!! go on son get it out!!!
Right!
That's settled it.
Out she comes!
Respect.....Norms
took around 15 mins to pull the engine from my Fiat 500.......Trolley jack is useful to support it as you pull it from the gearbox....Then you can lift it away by yourself !
Try doing that with a Moggy thou engine :)
Gerry
Small Tip: There should be a wee sheetmetal guard at the bottom of the flywheel held on with 2 miniscule bolts....I missed them and no amount of hauling woud shift that engine !! Amazing how 2 wee bolts caused so much cursing...
Cheers Gerry,
I shall keep a eye for the little beggars.
Fifteen minutes sounds great. I could only manage 30 minutes for the Moggy engine.
Regards.....Norms
gerry its good you still had the guard most of them fall off on the road!!!
I still have mie it's useful to catch all the oil leaks :D
