Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: James on February 06, 2008, 03:38:57 PM
Title: Head Gasket again
Post by: James on February 06, 2008, 03:38:57 PM
hi i'd like some help on everything to do with fixing a blown head gasket.
such as where is it?
what needs replacing?
what tools +knowledge needed?
how hard it is to do
thanks
james
(Bis of course)
Post by: James on February 12, 2008, 07:00:25 PM
Post by: Gordan on February 12, 2008, 07:04:33 PM
Havent done it myself, heres a bis manual which has it all described together with pics, should help..  :wink:
http://www.126bis.de/en/divers.html
Post by: James on March 05, 2008, 04:30:29 PM
thanks but i'm a little lost on how to navigate that page
Post by: stuey on March 05, 2008, 06:16:19 PM
such as where is it?  the head gasket is located on the right hand side of the engine bay between block and the head (to the left of the carb)
what needs replacing? its best to buy a full gasket set an replace all the gaskets that you remove when the head is removed), you will also need to get the head skimmed (most engine shops can do this for you)
what tools +knowledge needed? you will need basic hand tools, a torque wrench and a trolley jack if youre gonna remove the rear panel which makes the job far easier)
how hard it is to do - not a hard job but (and I mean this with no disrespect) if you dont know where the head gasket is it might b best to get a mechanic friend to help) the hardest part is putting it back together an ensuring you torque the head up correctly and seeting all the valve clearences correctly.
Post by: stuey on March 05, 2008, 07:18:27 PM
heres a pic from when i removed mine-
(http://i7.photobucket.com/albums/y271/cheekos10/DSCN0995.jpg)
Post by: Gordan on March 05, 2008, 07:56:33 PM
hey stu, i know you probably know twice as much about engines than me, but one question, wouldnt it be easier to take the engine out and than work on it?? cheers
about that manual, just klick the link, scroll to the bottom of the page and choose the bis manual from the menu... :cool:
(http://club126uk.co.uk/forum/userpix/559_untitled_7.jpg)
Post by: stuey on March 10, 2008, 08:26:40 PM
youre problee not wrong I just tried to disturb as little as possible doing mine cos it might have meant more broken stuff!!
personal choice I guess, tbh apart from re-fitting the exhaust its an easy job.....
Post by: Pete126 on March 11, 2008, 07:39:25 PM
My Philosophy is why make work for yourself. its an easy job to do with the engine in situ with the added bonus that the head nuts are easier to undo and re-torqued without the engine moving about. the hardest part is the two rear nuts at the back of the carb, but these can be undone and retightened with an open ended spanner. :)
Post by: Gordan on March 11, 2008, 10:51:50 PM
im sure youre right, but id rather now have to do it at all, if you know what i mean :wink:
