Fiat 126 Chat => Fiat 126 Chat => Topic started by: jon.hunt on January 31, 2008, 04:00:18 PM
Title: Lowering
Post by: jon.hunt on January 31, 2008, 04:00:18 PM
I'm after lowering the rear End of my 126 air cooler to get either no Camber or Negative Camber,  Do you take out your rear Springs and just cut them to 15cm  on the Bench?  and is it an easy Job to get the Springs Out?  About 3 Hrs a side?   Would I have to do the Front as well?  Don't know how to do that.
                                            Jon.
Title: Lowering
Post by: stuey on January 31, 2008, 08:04:37 PM
john, be cautious when lowering the front end 15cm spring do make the back end very low -see below but its a fairly easy nuts and bolts job.
 the front end is easy you can get a reverse eye front spring from various companies (I use priorettis as the are UK based and you can order from the web easliy)
(http://i7.photobucket.com/albums/y271/cheekos10/SS850730.jpg)
Title: Lowering
Post by: MaLi on February 01, 2008, 07:46:36 PM
Try cutting 3/4 of a coil - it should be roughly ok for 0 deg camber. It always depends on how tired are your springs.
You can always cut more later if you think its not enough. I would say 3-4h to do rear when you do it for the first time. Next time it'll take you <2h.
Regards
Mali
Title: Lowering
Post by: phreak97 on February 17, 2008, 05:54:52 AM
just clarifying, what do you mean by 3/4 ?
Title: Lowering
Post by: MaLi on February 17, 2008, 02:26:01 PM
From the top view: 270deg of the first coil.
Title: Lowering
Post by: ciaoflyer on February 19, 2008, 04:55:26 PM
It would be great if someone could post a step by step guide on how to do it.  I'm intrested in lowering but have not got a clue how?
Title: Lowering
Post by: jon.hunt on February 22, 2008, 03:04:13 PM
Hi All,
        First a Big Thank You for all the Help this Forum and it's Members have given Me.  I  just thought I'd Post how I Lowered the Back of my 126, I Jacked up the Side of the Car, then took the Rear Wheel Off. I then Undid the Bottom of the Shocker so I could pull the Suspension Down to loosen the Spring and Turn it to where I wanted to. I then got my 6inch angle grinder and cut Three Quarters Ie:- 270 Degrees of a Coil Off whilst the Spring was in Situ. Then reconected the Shocker and put the wheel on, about 20 Mins, Per side of the Car in Fact REAL Easy. P.M. Me if you want more info, but remember I'm a Beginner not an Expert.
               Thanks Again       Jon.
Title: Lowering
Post by: ciaoflyer on February 22, 2008, 04:28:11 PM
Any photos?
