For Sale & Wanted => Wanted: => Topic started by: VESPA210CM3 on January 18, 2008, 10:25:08 PM
I'm searching for a english Fiat 126 glovebox ...
yes english one for my french Fiat 126 (left hand drive), to be able to install 2 speakers on the front like this one :
(this one is an english 126 with a french/continental europe 126 glovebox)
(http://a491.ac-images.myspacecdn.com/images01/44/l_204331a6ced5e3201996d1fe445156c2.jpg)
Hi Vespa, another alternative is to fit a speaker pod you should be able to make one.
looking at the your picture you might scrape your shins by fitting a rhs pod cause there's not alot of room under the steering column. on my 126 it has a pod.
(http://club126uk.co.uk/forum/userpix/169_New_P1010105_1.jpg)
(http://club126uk.co.uk/forum/userpix/169_P1010103_1.jpg)
or if you want better sound, put in a pair of good quality door speakers.
Hi Pete, thanks for your infos.
With what material did you made your "pod" for the extra speaker ?
about door speakers, is there enought room in the door between door cards and the door itself ?
thx
i've seen some pioneer 4 1/2"--5" door speakers mounted in the plastic vynil just in front of the door pocket, under the 1/4 light, best to take the door card off and have a look where the holes are. the front speaker in mine was an optional fiat extra, but you should be able to make one out of 8-10mm MDF or PLY just glue and pin.
