Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Gordan on January 08, 2008, 04:26:31 PM
Title: Help needed. Cooling problems
Post by: Gordan on January 08, 2008, 04:26:31 PM
Folks I need help! Today, while I was doing a normal round to the city and back, my 126bis expirienced a "problem".
The engine just about reached its normal temp and WUSH! -smoke and coolant started to enter the passanger compartment through the Heating-cooling system.
i stopped the car and had it towed home. what happened was the water got hot and the little hose for bleeding the heating radiator ruptured and let out all the coolant.
what i dont understand is how the engine got so hot so quickly (it newer did before) and why the radiator was warm but not wery hot???
the thermostat was remowed by the previous owner and we had no problems so far.
Im confused if the blown pipe was the problem or its a symptom of a bigger problem.
any help would be gratly appreciated..
 :cry:  :cry:
P.s. Shuld I install a thermostat??
Post by: bis13 on January 08, 2008, 04:33:27 PM
well the water is going to get hot the thermostat normally opens at 70degrees it just sounds like the pipe has perished somehow , replace the pipe and fill it up again and get going, keep an eye on it and any problems report back to the forum. mick
Title: Cooling System
Post by: banjomandolin on January 08, 2008, 08:53:25 PM
According to my Bis manual the thermostat "starts opening at 85-89 deg.C"
and is "fully open at 100 deg. C.".
banjo.
Post by: Gordan on January 08, 2008, 08:55:43 PM
Im hoping too that the pipe was the problem, ill fill it up tommorow and hope for the best...
The thing is there is no thermostat in the housing, so the coolant flows freely between the radiator and the engine, it slows the heating of the car but shuld pervent overheating, hopefully.. (i think :?: )
Post by: Gordan on January 09, 2008, 08:58:50 PM
Fortunately it turned up that the pipe was the problem. I just cant beleive that such a small pipe culd make such a mess of my car. The passanger compartment was full of rusty coolant, the glove compartment was flooded and the front boot was completely messed up! it took me 5 hours to clean it up and im still afraid that the antifreeze may damage my paint...
Oh well, a nother usual day in an bis owners life... :lol:
Thanks for the input guys.
Just one more thing, Id like to hear your opinion on the thermostat matter, shuld I install one or not, its quite expensive but if it helps to preserve the engine, ill do it.
P.s. Even after this, i still wouldnt trade it for a aircooled one  :wink:
Post by: bis13 on January 10, 2008, 09:40:46 AM
the only drawback of not running a thermostat is the engine takes longer to warm up , but then again others will dissagree so just do what you thinks right . as it is it runs okay? then if its not broke dont fix it.so to speak . although you dont have one so it cant break........ :)
Post by: Gordan on January 10, 2008, 06:59:59 PM
I took it for a little spin today and it runs great, just as it used to. It takes about 15min of driving for the fan to start working.. i dont think ill install one cause summer is comin and it gets quite hot over here so i dont want anything to go wrong.. now all i have to do is clean the oil filter and the engine is done.... :lol:
