Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: 126dave on December 16, 2007, 05:58:22 PM
out for a run in the 126 today,dropping down through the box for a tight right hander,and,it just wont go into second gear.
the rest of the box is fine no noises nothing,in the workshop,if i hold it tight against the second gear selection,the car JUST drives........
all very odd,and inconvenient as the car has finaly got a buyer............any ideas? i know the easy way is to pop the spare box in,but i really cannot be bothered,if there is no easy fix the car will go as spares or to the dump,im flying out in january !
have you checked if the rubber flexible gear linkage mounting is tightened securely?
ah yes,i should have mentioned that,all has been checked,including the shifter adjustments.
its def an internal fault, i built the gearbox(bis/aircooled hybrid),it has run perfectly fine until this incident,i realy cannot think wat has hapened or wat i did wrong on the rebuiled.i just thought this may have occured to someone before and there may be an easy fix.
i really have no time to do engine out gearbox swops etc,so if the chap declines to buy it it (the car) will be scrapped.
:cry: :cry: :cry:
Don't scrap the car! I'll pop over for it :???:
i once had this but only after popping out of second for a week or two.
led to an emegancy driving lesson for my son (12 at the time!) (but then i DID end up with a limited slip box!!)
the only thing i can sugest is :-
GIVE IT TO ME!!!!! :twisted: :twisted:
my boy is now 15 and want's to be an engeneer, he thinks it would be a good idea to learn how to do thing before trying to tell peeps what to do!
(he'll do. i'll not send him back)
so if anyone has o LONG prodgect in s.wales i migh send him along
Dont scrap the car! I will take it back to norfolk with me! Where is it you are going again? malaysia? Think my girlfriends family have a house there.
