Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: jammy on December 08, 2007, 03:38:28 PM
Hey guys,
I gotta an issue thats killin me. The beast wont go to the point ive drianed my battery trying. To fill you in the garage took a look and thought it would be a good idea to dismantle the carb and then put it back together (leaving the choke link off !). anyways she still wont start she just turns over and over and over until i eventually get a loud (and i mean loud) pop from the exaust, now i did try a few things which include checking the carb was dumping fuel and the HT leads, the distrubter, WD40'ed everthing in there. But the thing that sorta sorted it was changing the sparks, it worked until the next morning then dead again, and then put the old sparks back in and she ran again ! until the morning that is. Im at my wits end as im not really what youd call a mechanic in any sense.
Please help as the missis is giving me hell as she has to walk to wrk in the cold. (never tell them its good for them either ! it hurts)
try taking the spark plugs out when it want start (after a load of attempts) if the plug electrodes are wet it suggest an ignition problem. On the other hand if they are dry it suggests a fuel problem.
The plugs are wet, what does that mean ?
if the plugs are wet then it means you are getting petrol to the plugs.so it is likely to be an ignition problem.
sounds like you may need a new ignition coil,quick test,remove the plugs one at a time,still atatched to the lead and place the plug on a metal part of the engine,have someone check the spark plug while you try and start the car to see if there are any sparks at the plug.your points may also need cleaning/adjusting.
it sounds likely to be an ignition problem. Are the contact points ok and set correctly?
turning it over and over will just flood it
i would check it had spark and then if it did turn the motor over a few times (without the plugs in) and this will spit all the unburnt fuel out the plug hole
hope this helps :D
okies, i think its my carb. I chked the sparks with a guage and i chked the dizzy was sparking ok, i took the sparks out like you suggested ran it and replaced them and bam it turned over. I think my fuel is to rich and i dont know where to adjust this on a WEBER 30 DGF. Can you guys point me in the general direction ?
thx for you help so far guys, im getting there. Youll make a mechanic out of me yet :lol:
what do you mean checked the plugs with a gauge?should be done by sight.Also,the dizzy shouldnt spark,if it does then your condensor has gone.
http://fiat126clubuk.freepgs.com/FI29CD.PDF
I would check the points and timing first
dan i think he meant feeler guage and not to be rude but the dizzy does spark (points).
the condensor is supposed to stop sparking at the points?
it suppresses the spark, although you should still get a light spark.
any garage that couldn't diagnose the fault on a non running 126 within half an hour is clearly staffed by ham fisted monkeys.
from your description it is either over-fueling or under-sparking :D
the fact that just changing the plugs allowed it to start might suggest over fueling from a sticky float/needle valve, this should be obvious as there will be a real stink of petrol from the exhaust and just general strong smell and overly wet plugs.
not sure if a 126 fuel pump can deliver too high a pressure as they usually go the other way and just pack in.
otherwise as suggested a poor spark is the usual cause of starting probs on a 126.
possible causes.
knackered condenser.(always carry a spare) points shouldn't spark but italian electrics are a bit poo so they sometimes do even with a good condenser
points gap closed or burnt from knackered condenser, clean with little bit of wet or dry folded in half, slip into points gap and pull out. then reset gap
condition of rotor arm and dizzy cap. inspect for burnt/damage, if unsure then replace.
connections on coil. check they are tight, free from corrosion and dry
HT leads, old/perished then replace
okies fella's, thx for help so far but where can i get a condenser ? i know, im usless :???:
:idea: got one from halfords last week
