Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Tomasz on September 18, 2007, 09:36:23 AM
Title: bis studs
Post by: Tomasz on September 18, 2007, 09:36:23 AM
In one of daves old posts he mentioned using two bis studs when fitting the panda head so you dont have to cut and re-thread the current ones, does anyone have any going spare?
Cheers, Tomasz
Title: bis studs
Post by: 126dave on September 19, 2007, 08:17:05 AM
hi mate,indeed the two studs that go into the intake port need to be shortened,bis ones do the job fine,but if you fit an alquati or simular intake manifold you will then need to LONGER studs at each end.....they are easy to make however.....do not be tempted to unscrew the studs from the block to make them longer,you will crack the crankcase when you torque them down.
so id say buy the die (if you get the spanner drive version you wont need to buy a set or the t bar)and make them,its easy.
dave
Title: bis studs
Post by: Tomasz on September 24, 2007, 02:24:20 PM
Cheers Dave, i think my girlfriends dad will prob have the die (if he can find one in the mountain of stuff in the garage).  I am just keeping the standard carb for now.
Just going to go out and make a start on the tin work!
Title: bis studs
Post by: 126dave on September 25, 2007, 07:56:07 AM
make sure its the correct pitch,and do not be tempted to change pitch and nuts to something at hand,that will change the torque reading.i cannot remember off hand the pitch,if you get stuck ill loan you mine
