Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: jpimpao on September 15, 2007, 11:17:08 PM
Title: Running rich
Post by: jpimpao on September 15, 2007, 11:17:08 PM
Hi All,
I have fitted a sports exhaust and have the valves clearence adjusted, try to adjust the carburator mixture screw and it runs well only if the misture is rich, doesn`t even the choke. I have tried to screw in and the engine starts doesn`t work propely, and I have noticed the car drinks a bit more, it starts well cold and when is hot, should I need to look somehere else or just don`t bother.
Title: Running rich
Post by: bis13 on September 16, 2007, 09:10:51 AM
you say valves adjusted was the engine running sweet before ? if so it looks like the valves are the culprits if not hows the timing? the exhaust should not affect the running as you describe it didnt on mine. by the way do you like the new sound? :lol:
Title: Running rich
Post by: jpimpao on September 16, 2007, 10:37:24 AM
Hi Mick,
I love the sound, i though it was going to be a lot louder than it really is. Well, actually I never had adjusted the engine before and sometimes I could notice it not running smoth, and had it a go and have it adjusted until the engine runs smoth, the engine runs nicely but as I mencioned I don`t to use the choke even when it`s cold and before I had to use it everytime i started the engine. I don`t know anything about timing.
I did replaced the spark plugs also.
Thank mate.
