Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: michaelodonnell500 on August 27, 2007, 06:50:57 PM
Hi.
Iwas doing a bit of work on the engine. Set the points at the haynes recommended .47 - .53mm and now it wont start. The points looked to be about .25mm before I set them. Can anyone verify that the haynes manual figures are correct?
Michael
Hi.
Michael
yes you have the correct figures.
It's worth checking the gap on both sides of the distributor lobe, to see if there is wear in the distributor.
Check the ignition timing with the new points settings, they are both related.
Good Luck
Chris Lewis
Cheers for that.
Given that they were operating fine at a very small gap, i reckon there probably a bit dead, I'll stick on a new set and see what happens.
Michael
