Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: dajwid on August 25, 2007, 09:28:24 PM
many use electric fuel pumps to replace the original for obvious reasons. Has anyone used one of these?
http://cgi.ebay.co.uk/BRAND-NEW-Electric-Fuel-Pump-RANGE-ROVER-3-5-VOGUE-etc_W0QQitemZ270156191014QQihZ017QQcategoryZ31348QQcmdZViewItem
If not what has anyone used that has worked?
thats going to have too much pressure, i use a facet solid state (red) pump i think its about 2.5 bar , if you want lower pressure just fit a regulator and set it lower.
http://cgi.ebay.com/ebaymotors/NEW-140-GPH-Electric-Fuel-Pump-Universal-_W0QQcmdZViewItemQQhashZitem4cf21accdeQQitemZ330479357150QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/Billet-Electric-Fuel-Pump-Regulator-w-Return-3-12-PSI-_W0QQcmdZViewItemQQhashZitem51954c6a02QQitemZ350397164034QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Am I right in thinking this little combo would be the ideal setup for a bis?
Why buy from the States ??? My experience is that the postage is very expensive and depending on HM Customs may charge you import duty and VAT Unless it slips through unnoticed, pumps are available in the U.K. this one should do the job Facet 1.5 to 4.0 PSI [-/
http://cgi.ebay.co.uk/FACET-PUROLATOR-ELECTRIC-FUEL-PUMP-UNION-1-5-4-0-psi-/270475822034?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3ef99d83d2
that looks like a better design than the old cube type i have been running the cube type for a few years with no trouble what so ever just make sure you fit a non return valve on the feed so the pump doesnt empty when the car is not running.
They were just examples. Been trying to figure my way around getting the pressure and the return right.
For the pump you linked to am I right in thinking although the pressure is right, I'd still need a regulator for the return since that's on the old pump on the bis?
The pressure is right, I have been running a similar pump with the same spec for the last three years with no regulator or return (Blocked Off) on my bis with no problems [-/ Once the pump reaches its max 4 PSI it shuts down until the pressure drops ;)
Awesome. Never thought about just blocking the return off. Figured it was required. :)
I left the return in place.
Nothing like an extra ticking noise to keep one company at the traffic lights :oops:
sorry to dig out an old post
if i was to install an electric pump, should i blank off the mechanical fuel pump or leave it in place?
or take out the push rod and leave the mechanical pump in place?
Other here have more experience but my mechanic.. removed the mechanical pump and blanked off..
Mine is still there at the moment, (just in case the electric one stops working) :cry:
haha, its doing all the sucking and pushing for nothing?
cheap date! :P
dave just make sure the mechanical pump is well blocked off as if you get crud in there its knackered, i would remove it and stick it in the bits box as the electric pump will go on and on with no problems...
What are the advantages of running an electric pump, i realise it will provide a more constant pressure? But what are peoples experiences on these, does it improve starting/responce etc.
Thanks.
