Fiat 126 Chat => Fiat 126 Chat => Topic started by: MaLi on June 01, 2007, 10:40:51 PM
Title: How to register imported 126?
Post by: MaLi on June 01, 2007, 10:40:51 PM
Hi everybody!
As my restoration 126 project has recently become a bit more "complicated" I am considering bringing it here at the stage it is now (completely dismantled). Therefore I need some advice from you on registering the imported car in the UK.
1. What sort of documents do I need to have to do it?
I am still the owner of the car in Poland but don't know how to transfer this ownership to the UK...
2. Do I need to pass some sort of an MOT before I am elligible to register it  or maybe I can register the car now and, later on when the project is finished, I can do all the tests?
3. Can there be a problem that in year my car was made (1992), they were not imported to the UK anymore and therefore they are not in the DVLA database?
4. Any other problems I can come across? (insurance, tax etc)
Many thanks for any help on the topic.
Mali
Post by: jpimpao on June 01, 2007, 11:23:12 PM
If you go to DVLA website, you will find everything you need to register your car.
Post by: fiatfsm on June 02, 2007, 09:56:28 PM
you should be OK for a 1992, as long as its not less than 10 years old it should be fine. you will need an MOT first, before it can be registered.
Post by: MaLi on June 03, 2007, 12:13:55 AM
Cheers. I will have a look at the DVLA website.
I had a quick chat with a mot tester about it today and he said I might have to fit seat belts in the rear but that shouldn't be a problem. Good news are that I don't need to fit catalyctic converter :)
The fact that I have ot pass the mot before I can register it means that the car will be still be registered in Poland for that time, what I would think should  be ok.
Thanks for help. Will ask for more info if I come across any problems.
Mali
p.s. does any body now of any garage or shed for rent in Leicester?
Post by: Tomasz on June 03, 2007, 11:09:44 AM
Hiya
Mine is only a year older and i had no problems.  Think you need a mph speedo and you will need to adjust the lights and stuff.
Cant really remember all we did 'cause my parents sorted most of it! hehe.
Post by: bis13 on June 03, 2007, 06:40:05 PM
kph clocks are fine .
Post by: Chris Lakin on June 03, 2007, 08:45:26 PM
yer i thought by law you had to swop clocks to MPH?
Post by: bis13 on June 03, 2007, 10:57:21 PM
well my car had kph clocks for mot its not required to be mph
Post by: fiatfsm on June 04, 2007, 07:09:47 PM
KPH is fine, my Vespa was new in 2002 and has one and its a UK scooter!
