Fiat 126 Chat => Fiat 126 Chat => Topic started by: Idle Steve on May 29, 2007, 10:10:53 PM
Hi all,
As it's been 10 years since my last Bis, who is the best for spares these days? I'm after a couple of gearbox mounts as mine are absolutlely cream crackered. :smt089
Thanks, Steve.
hi mate, the BIS gearbox mounts are quite expensive,
www.ricambio.co.uk are your best bet give them a call, they are reliable youre looking at £30 +
have a look at this site the guy is a buggy builder but used poly bushes to replace the mounts , its well worth a go and they will last longer.
http://www.k9rdj.co.uk/mybuggy/chassis.htm
mick
The Poly bushes look quite good, however the rubber ones are designed to move a fair bit damping out the vibration from the body. The only thing that worries me a bit is that there will be too much vibration carried through to the body causing my false teeth to fall out! :smt093
What do other people think? :|
part of the reason the bushes go is the fact that the clutch is usually contaminated with oil,causing savage take up on the sticky clutch,every 126 i have worked on has had the gearbox input shaft seal weeping,i reckon the standard ones are ok with a good clutch and driving technique
It's had a new clutch before I got it (and a reciept for a new crankshaft oil seal no less!) The clutch is quite nice, the rubbers have perished due to old age (know how they feel!) :sad:
Has anyone used this website ? https://ssl.kundenserver.de/shop.fiat500126.de/indexa.htm
The parts look cheap and the postage is not bad if you buy a few things.
the front crank seal goes as well...... :wink: gerstl are good for standard parts,but some here have had long waits tho....
achtung!! jonny!! givs me vor monzey unt i back orderz ze partz!!
if you do as uncle Dave has said in another string, email them first to make sure they have the parts in stock, i had to cancel part of my order after waiting 10 weeks,
