Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Idle Steve on May 26, 2007, 10:36:31 AM
Does the dizzy vacuum advance pipe go to the connection on the base of the carb or the one on the inlet manifold? 126(bis).
Mine was connected to the idle diaphram on the side of the carb which was doing bugger all to advance the ignition :smt009 (I also wondered why the revs didn't increase when the fan came in!) Two problems solved in one. :D
I assume the inlet manifold connection goes to the solenoid then to the idle diaphram? :smt017
Any info will be great!
Steve.
on V8's the vacuum goes above the throttle butterflies so that when you open the throttle wide there is more vacuum and it adjusts the timing. cant see why it would be any different on a 126.
the dizzy vacume advance pipe runs to just below the diaphram on the right of the carb.
the pipe from the revs increasing unit wih the adjusting screw in the top runs to the back of the solenoid and from the front of the solenoid to the inlet manifold below the carb at the front.
the reason you revs are not inreasing when the fan kicks in may be because the fuse as gone, or it may be that the adjusting screw in the top of the unit is closed right down, or it could be that the arm that incrases the revs at the back of the carb is corroded solid.
to check if the solenoid is working listen for a loud klick when the fan kicks in and out.
Thanks for that Neil, I guesed it correctly. The previous person had connected the dizzy pipe to the revs unit! (doing nothing for the vacuum advance or the rev up thing)
Everything went well untill the fan cut in then the engine started reving like mad as someone had adjusted the screw all the way out on the revs unit!!!!!!! Anyhow it's all adjusted ok now.
Thanks for your help. Steve.
its nice to hear that problems like that get sorted, its rewarding to hear people sorting problems from asking on here,
usualy its just endless problems which nobody really knows how to sort and they dont come back on here to explain how they fixed the problem in the end, so we never know how it was solved.
