Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: neil 126 on May 21, 2007, 10:49:07 PM
there is a lot of oil being forced out the breather pipe, especially at high revs. there is also a cough and lots of fuel mist being thrown back out through the top of the carb at high revs often with a bang.
i dont want it to be so, but i think the piston rings are worn, what do you think?
p.s. the timing is good, it has new HT leads, and new spark plugs, the carb has just been thouroughly cleaned and i don't think there is a vacume leak.
all help mutch appreciated.
neil.
well,the carb on a standard engine needs the small amount of ''super charging'' from the fan ducting to help stop reversion at high RPM(due to cam/valve timing),thats the fuel misting your seeing,popping back through the carb is part of the same symptoms....all normal,and only noticable as ''sneezing'' when the aircleaner/carb piping is all in place.
as for the oil being thrown out,there is a hell of a lot of rocker cover pressure variation as the twin pistons rise an fall,id check oil level,then the correct operation of the oil filler cap before condeming the rings to the bin,the filler cap is critical,as is the rubber stopper on the dip stick,crankase/rocker cover pressures are higher than other engines you may have dealt with.....hope this gives you hope ! :cool:
thanks dave for your help, but i'm still not sure.
i have a bis and there is no fan ducting.
the car definately does not run right at high revs, what else could be causing this?
it only seems to cough and pop when on full throttle when the 2nd barrel opens up.
P.S. i am testing the car on ramps not on he road, the breather vent from oil filer cap to air box is off and the carb inlett muffler is off.
Have you tried a compression test?
from what youve described about it not running right, sounds more like the timing may be out.
but as Chris Lewis says, get a compression test done, then you will no for sure, otherwise you will be spending money through trial and error.
Thanks guys, you are wright about the compression test, i should get one doen before i start condeming rings.
Just one further thought though, could it be as simple as too much fuel being dumped into the carb? When the second barrel opens up there is a lot of extra fuel Being sprayed in from the jet at top of the second barrel.
Is there any adjustment available to the amount of fuel being sprayed in?
If so, where and how.
neil.
have you checked the carb float to see if its sinking and causing over fueling? Also do you have a flat spot? the pump diaphragm goes and causes over fueling.
also mate, ive very rarely come across a 126 with worn piston rings, i mean im not saying that they never go, but i just havnt heard of many. Has it got high milage?
worn valve train can also cause spitting back through the carb.
the head gasket may have gone.........but not to a water way,then compression could be blowing oil up and out,and the engine could well be 'crossfiring' between cylinders.just a thought...
things just aren't going my way at the moment.
having checked the valve clearances and replaced a suspected fractured wire and replaced points and condenser i have lost all spark entirely.
i have to get things sorted out pretty quick as we are moving house again this month.
you say you have no spark at all , take the dizzy out and put the car in gear then with aid of a torch see if your cam is moving by moving the car back and forth you will be able to see if the gear that connects to the dizzy is moving if its static then your timing chain has bit the dust, its something i have had happen to me just a thought.
Neil, If You remove your distributor, be sure to set the timing up with the engine static as you put it back in, ie; take out the spark plug nearest the dizzy and rock the car in 4TH gear,'til the no.1 piston is at top dead center,(the movement can be seen with a thin screwdriver in the spark plug hole.).Apply the handbrake, then replace your dizzy but keep watching the points as you do it. Note their movement in degrees and direction, then remove and replace the dizzy so that when it is firmly seated, the internals have twisted until the points are wide apart. re-check your points gap after tightening the dizzy down.If it runs (after re- fitting the spark plug :wink: ) that will take care of the timing, (but checking it with a strobe light when running is best.).Other than that i would suggest replacing the condensor(again, as i have brought dead ones from shops before)and then suspect the coil mate.hope that helps?
thanks everyone for all your help with things so far, but i am now sure this is an electrical fault.
the supply lead to the coil pack is not going live, my guess is that there was a poor conection some where or a fracture allowing arcing, but now there is nothing, the fualt is definately before the fuse box somewhere,
i have been looking at the buse box and it appears to be that the orange coil-pack feed (it is blue in the engine bay but is orange just before it passes through the bodywork under the rear seat.) is not going live.
the orange wire is feed via the indicater fuse.
i think that there is something wrong with the power to the indicaters too as the flash is weak and slow.
i have not checked the rear screen heater operation as it will drain the battery too quickly if it is working ( i assume it is not as all three things Indicaters, Coil-pack feed and Rear screen heater are all interconected)
Can one of you clever electical wizzards please help me out here as i am out of my depth when it comes to electrical things like this.
maby an ellectrical diagram would be helpful or if you can tell which wire to check ( there must be common supply feed to these items but i dont know which it is)
please please help me.
p.s. just to allay any fears that i may have missed something simpler,
i have checked the coil pack, plugs, HT leads, condener, and points on my other Bis and all are working well. i have also run a new wire direct from the fuse to the coil-pack to illiminate the possibility that the orange wire is fractured.
When you ran the seperate wire from the fuse box to the coil (ie Live) then I assume the motor ran OK? :D
If that is so then why not route the new wire and leave the other disconnected? Problem solved (sort of) :???:
Have you checked the ignition ballast resister mounted on the front panel behind the spare wheel, as for the indicators is the battery fully charged or it could be a bad earthing point
Sorry, just read your post again, are you saying that the fuse is not coming live when the ignition is turned on?
Me again, :D
According to the manual it states "The following circuits are not protected: Ignition, Starting and low oil pressure warning light"
That means that the ignition must be a direct feed from the ignition switch and does not go via a fuse. Try looking and testing around the steering column, maybe the ignition switch is faulty? :???:
The fuse you are looking at only does the heated rear window and it's warning lamp and will be dead because I'm sure the relay only operates when the alternator is charging (engine running) so it cannot be left on without the engine running.
If you have no luck I will trace my feed for you and see where it is fed from. (I assume you have a Bis?)
PS here is a link to a online manual but the site is down at the moment :cry: http://www.fiat126.hu/book.php?book=15
Steve.
hi steve thanks but no the engine did not fire up, stil no spark.
there must be some power but not enough to induce a good electromagnetic collapse in the coil, this is my thnking behind the por operation of the indicators.
hi pedro what is this ignition ballest resistor. i do know of a it located behind the spare wheel but what does it do and how does it work?
hi steve i think when it saiys thet the ignition is "unprotected" it mea ns that the starter motor is unprotected as this reqires a lot of power to operate, therefore it is feed direct from the battery, and not via the fuse box.
The engine does turn over quickly when the ignision key is turned.
the wire that is not going live (the orange one at the fse box/blue at the ignition coil) should be live in order to power up the primary coil in the coil pack, the primary coil is collapsed when the points are seperated thus inducing a high voltage pulse to HT leads.
thanks neil.
Hi Neil
Ballast Resistor: is a resistor that is switched in and out of the 12 volt supply voltage to the ignition coil. check the connections as this is the supply to the coil, The ballast resistor lowers voltage after the engine is started to reduce wear on ignition components. It also makes the engine much easier to start by effectively doubling the voltage provided to the ignition coil when the engine is being cranked. in the olden days they used a lower voltage coil 6v 9v when the resister is cold it passes 12v as it warms up it goes high resistance and brings the voltage down to 6v 9v or what the working parameters are, if you have a meter you can measure the voltage to rule another thing out of the loop.
this fault that you have is exactly as i have had recently where the orange meets the blue there is a slide connector in a little plastic clip box make sure they are connected as i found mine were just laying on top of eachother!
The 126 Bis does not have a fancy heated rear window which only comes live when the engine is running.
You are quite right about the orange wire at the fuse box as I have been following the wiring diagram.
There is a light blue wire which runs from the ignition switch to the back of the fuse box on fuse No 4 which is the indicators and then loops to fuse N0 2 which is the HRW.
From this loop is the orange wire that you are talking about.
If these fuses are dead with the ignition on then the fault has to lie between the ignition switch and the fusebox
Does the alternator light work as this is fed off the same circuit with a light blue wire from the rear of the ignition switch?
The ignition circuit has no fuse whatsoever as it is on the primary side of the 2 fuses which only affect the indicators and HRW, ie you will find when your problem is solved you can remove every fuse in the fuse box and the engine will still run!!!!!
Not good as any fault on the ignition could set fire to your car! (don't want to put you off, this was done a lot on older cars.
Link to ignition diagram & key:
http://www.fiat126.hu/books/15/141.gif?PHPSESSID=1906b3d53d350ca7af61fee075c0e1c1
http://www.fiat126.hu/books/15/147.gif?PHPSESSID=1906b3d53d350ca7af61fee075c0e1c1
http://www.fiat126.hu/books/15/138.gif?PHPSESSID=1906b3d53d350ca7af61fee075c0e1c1
Check out the diagrams and see for yourself,
Steve.
Hi Neil
What a cracking explanation of a ballast resistor!
The resistor by the spare wheel is actualy the dim dip resistor (somthing that was fitted to cars around that time which turned the headlights on at half brightness when the ignition was on and the switch in the sidelight postion) This was to stop people driving at night with only the sidelights on.
If you turn on the ignition, put the sidelights on you can feel the resistor warm up (Dont stick your finger in like I did, it hurts :oops: ) You will notice that the headlights are on dim.
The coil on the Bis is 12volt and does not use a ballast resistor, so the voltage at the coil should be 12v.
One less thing to worry about Neil!
Steve.
Hi Steve, totally confused me now (which does'nt take alot) in the manual it say it has a resistive wire
(http://img77.imageshack.us/img77/2739/newuntitled1ul3.jpg) (http://imageshack.us)
and also on a previous string
http://www.fiat126club.co.uk/forum/viewtopic.php?p=3204&sid=d7e47223e2d7011fa7dafd3616515cdd
Bugger, you have got me bang to rights, the diagram I have shows no resistive wire where as yours does?
Just been out to the car and checked the live feed to the coil with the ignition on and I have 6volts (DoH!) but the ballast resistor must be part of the wire as it is not the resistor by the spare tyre.
Have you checked the wire from the ignition swith yet?
Try running a wire from the battery positive to the dead fuse and see if she will start? If she does then the fault must be between the fuse box and the ignition switch!
Steve.
well i'm sure it won't be long now, but there is yet another obstacle in my path to nirvana.
there was a loose conection bethind the hot air fan at the bulkhead, the indicators are on and i am getting a good spark at the plugs but the bloody thing will not start.
i have checked the pistons for movement, ( you can tell i am getting desperate) and they rise and fall as they should, i have checked the valves previously but i think that there must be something wrong here. maby the pushrod has got stuck or bent. or maby the rocker/tapetts mounting is loose and not giving proper movement to the valves.
does anyone else have eny other ideas?
this is turning out to be a real test, not just of my mechanical/electrical knowledge but of my patience also.
p.s. the current symptoms are this.
the engine turns over quickly, there is good spark from the plugs,the pistons are moving, there is petrol going into the inlet manifold and thus to the cylinders, but there is no explosion. not even a puff.
i will try turning over agian tomorow morning just in case it is flooded, but i am not holding my breath.
thanks neil.
it sounds like the timing is simply out get someone to crank the engine over and move the dizzy till it fires up, make sure you have made a mark on the dizzy and base to realign if not successfull. another thing is get some easy start and give that a go.
Have you just bought this car and never had it running properly or has it been fine up untill this fault?
Did it slowly get worse or happen instantly.
I had the starting problem once after checking the timing, good spark but would not fire. It had driven 110 miles the day before perfect, left it till the following day still nothing. Went back to the dizzy wobbled all the wires etc then started first time (never did find the problem all connections were fine and a big blue spark, it's been fine 300 miles later). Fiats!!!!!
Steve.
the sort of agro neil is getting sounds very similar to what i am getting right now with my polski, i have spark, fuel, and everything seems okay but to start the car is a bitch. however if i spray a bit of easy start into the intake it fires up no problem , and afterwards when i start the car it fires up ok. its only the first starting .
Neil, you can check the timing static by removing the plugs and re-connecting the leads, place the plugs on top of the engine.
Remove the dizzy cap. Look for the little notch on the crankshaft pulley and mark it with some tippex if it's not been done already.
Turn the engine round clockwise untill the pulley mark is about 2" from the timing marks by the top of the pulley (I use a screwdriver and gently turn the alternator fan blades to do this.)
Turn on the ignition, turn the pulley slowly, the points should open and the plugs spark when the notch on the pulley is at the first mark of the pointers (this is 10 deg. before TDC)
If not adjust the dizzy either way and re-check untill spot on.
(you may have done this already if so ignore this, it may be of some use to someone else.)
Have fun, keep us posted! :D
hi guys
steve this is a new car to me but it did drive 200 miles from preston all the way home. it has always had i bit of a cough. hence the carb cleaning.
when it dicided to cough and die it was definately running on just one cylinder for about 20 seconds and then it spluttered to a halt.
i think i am going to have to leave things to the weekend as by the time i get home the mighty midgies are out in force, making working outside unbearable.
thanks for all your help, i will let you know how things deveplope.
cheers neil.
