Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: bis13 on May 15, 2007, 08:06:27 AM
Title: bloody stupid starter cables!!!!!!!!!!!!
Post by: bis13 on May 15, 2007, 08:06:27 AM
why is it that my starter cable keeps breaking ?!! its not breaking in a place where it might rub but at the connection part at the starter end!!!!
 i am now going to look at a bigger thick steel wire rope jobbie and run it through a different route as its crap as it is and i aint buying anymore cables!!! on top of that i burnt me bloody arm on the exhaust when i started the bloody thing up while hot!!!! dont laugh it could be you!!  :lol:
mad from kent..
Post by: Chris Lakin on May 15, 2007, 11:13:52 AM
revenge is sweet Mick  :lol: , i sabotaged your starter cable, after i caught you laughing at me for starting mine with a jack handle (because my cable broke a while ago)
and yes ive burnt my hand on the exhaust a few times from starting it like that  :lol:
Post by: andrewblears on June 05, 2007, 11:23:22 AM
I have the same prob on my bis the plugs wich go on the starter are crap
Post by: bis13 on June 05, 2007, 04:58:10 PM
mate the bis is luxury compared to the crude aircooled starter cable system .
Post by: hudsonhenry on June 05, 2007, 05:46:31 PM
I'm just waiting for the day Chris leaves his car in gear by mistake – one push on the starter and it will be trundling down the road on its own leaving him bent over an empty space with a jack handle in his hand :twisted:
Post by: andrewblears on June 05, 2007, 05:47:48 PM
the firs time i drove my car the plug just fell of
Post by: Idle Steve on June 05, 2007, 05:59:26 PM
Why not replace the stupid pull thingy with a 12v solonoid? Then wire it up to a push switch on the dash (just like those big fast cars, And Renault Lagunas.)
The larger motorbikes still use them and the early Fiestas used them too.
May find one in a scrappy.
Save you getting stressed out!! :smt030
Post by: hudsonhenry on June 05, 2007, 06:09:28 PM
Or wap it for a later 126 starter with the solonoid already fitted, its an easy swap and can be wired into a dash switch.
Post by: Idle Steve on June 06, 2007, 04:58:11 PM
Here you are Mick, swap it for this. :D
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=190120197062&ssPageName=ADME:B:SS:UK:1
Problem solved.:mrgreen:
Post by: bis13 on June 07, 2007, 04:14:46 PM
its called the" being arsed to do it factor " if the starter motor gives up on me then i will be arsed but until then the arse factor is 0! it was far easier to whack in a big cable , and to be honest if i wired it up my lights and wipers will probably come on at the same time !!!
Post by: Idle Steve on June 07, 2007, 06:18:07 PM
Get one of these on it! It'll pull the engine out before snapping!
 :D http://cgi.ebay.co.uk/Kryptonite-Flexible-Vinyl-Coated-Steel-Cable-2134mm_W0QQitemZ290125756013QQihZ019QQcategoryZ98855QQrdZ1QQcmdZViewItem
Post by: bis13 on June 07, 2007, 06:41:35 PM
thats the same thing i pull my sons teeth out with!!!!
