Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Frank126 on May 05, 2007, 07:21:58 PM
Hi. all 2 days ago I started my bis in the morning and the battery light remained on all the while, I noticed the more I pressed the throttle pedal the dimmer it went, I used it yesterday with the same problem but everything worked fine until this morning I found a flat battery, I charged the battery and refitted it, but still the light is still on, anyone had a simliar problem?
you have a charging fault, could be a faulty alternator.
Yes I suspect alterator as this happened on mine, changed it and it stopped.
word of warning with alternators,if you flatten your battery and need to re charge,you must disconnect the battery!.you can burn out the gubbins inside the alt if your not carefull.................
yep u were right it was the alternator, somthing inside, the elctrician told me its common he refurbished it and its working fine now :D
i have the lamp of battery on when i am on no load and the car does not stop i have heard thats right to be the lamp to be light on the no load speed is this right?
