Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: ciaoflyer on May 02, 2007, 04:26:12 PM
Hi
How do I remove the knob on my Bis as I want to change it. Been trying but can't figure it out?
Ta
it un screws.......while your at it,cut 3 inches from the lever,it makes a lot of diff to drive....
yer the old bloke who had my car before cut gear stick in half,
feels alot better to drive, seems to slip into gear better, i think long gear stick provide too much leverage.
Troublr is when I try to turn it the whole thing turns incuding the shaft, do I need to grip this somehow?
My BIS has the same problem, the whole shaft moves when you twist the knob
All i do is hold the stick and the knob should soon come off after a bit of twisting! :D
what i did was hold the shaft with a pair of mole grips, and unscrew the nob with a pair of pipe grips, it does go :wink:
yes thats the way,and while you've got a grip of the bugger chop 3-4 inches off..........i fitted a small bakelight knob,its great,i can get these for anyone who wants one foc
does it really make a difference? i might try that
