Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Frank126 on March 21, 2007, 04:51:13 PM
Hi ca anyone tell me how to remove a carb off a bis? as i removed all hoses and connections and removed 2 nuts from the side of the block are there any other nuts or anything keeping it connected to the engine block as it doesn't want to move!? Thanks
Hi
Yes there are two more on the otherside. In total there are four, one in each corner. They are quite difficult to remove. I use a small 10mm Spanner and eventually you will get them off.
Hope this helps!
thanks i managed to get it off! :) has anyone of you had problems with broken choke linkages? as mine both have their chokes broken :( can these be repaired? Thanks
is it the polish carb with the choke arm inside the carb? if so yes they are a pain in the arris, i dont know if a repair kit is available you could try .the problem is the arm is made of plastic and eventually breaks.
Hi thanks yes it is infact the previous owner told me that some plastic was broken and that's why the choke isnt working! Thanks for your help
also is there some sort of mark to recognize which carb is good for my car cause I'm seeing some carbs on internet from axel gerstl but looks different from mine! Thanks
theres two types of weber for the bis the polish type weber which you have already and the real weber . get the real weber as its choke is on the outside its bassically exactly the same but just looks different and will fit straight on to your engine . theres a couple on e bay also have a look in the 500 mania site in links on the club home page. they do a cheap refurbed 30 dgf.
