Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Dom on March 15, 2007, 07:00:10 PM
Title: Washer pump woes!
Post by: Dom on March 15, 2007, 07:00:10 PM
I have have been having ongoing problems with the windscreen washer system of my 500 - I have gone through 3 pumps in 3 months! When a new pump is fitted, it works perfectly but then stops working after about 2-3 weeks. It looses all its pressure completely and becomes too spongy to press.
Has anyone had similar problems or does anyone know what the cause could be?
Though not the most expensive item, they are difficult to get hold of and are crucial to pass an MOT.
I have also tried replacing all the tubing and have tried 2 new bags. V. annoying!
Perhaps I am buying a poor quality pump? I have used both fiat500ricambi.nl and axel gerstl. Can anyone recomend a good UK supplier as I need a new one soon as MOT next week. The only place I have seen is fiat500.cc, but it is very expensive for a part which I will probably need to replace again within a month
Post by: bis13 on March 15, 2007, 07:26:09 PM
are you talking about the manual pump? why not just fit the electric pump? if you want one i will send it to you this time by cheap post!
Post by: Dom on March 15, 2007, 07:31:13 PM
Yeah, the silly little black sqidgy push buton. A mechanical one would be cool. how and where do you wire it? What is the switch like? It's kind of fun pushing the little squdgy button, but not when it doesnt work! Is the washer imperitive for MOT? I'm sure it is, though there ios not a section for it on the form...
Post by: bis13 on March 15, 2007, 07:50:20 PM
no working washer is a fail , i will send you all the bits for electric conversion , you will need to by a switch from halfords . just find a suitable place in your car for it . wiring is to a live and earth its easy you can go straight to your battery as the switch breaks the circuit so no worries of drain. get one that springs off (switch) . just send me your address again as i have deleted all my previous pm s , cheers mick
Post by: ChrisRLewis on March 15, 2007, 08:10:30 PM
I would guess that there may be a problem with a one way valve usually fitted to most washer systems?
I converted my 500 to electric ,used a washer bottle with an electric pump built in, it is very similar to the 500 original bottle and is a direct swap. If I remember the bottle came from a Fiat Uno?
I added a switch which was a large push type switch the same place as the original 500 switch with a new bracket similar to the 500 original style.
Wiring was easy if you go along this route I can explain the wiring if you are stuck!
Chris :)
Post by: Dom on March 15, 2007, 08:19:00 PM
that is definitely the problem. The one way push valve stops working after a few weeks, so the pump fails to suck in the water to squirt out. Why would this be happening, and is this fixable, as i have a stock of about 4 pumps with with problem. Electric sounds like the way to go for sure...
Post by: ChrisRLewis on March 15, 2007, 09:02:30 PM
Electric is the way to go!
This is similar to the switch that I used, make sure that you dont get a switch that locks to operate.
http://cgi.ebay.co.uk/PUSH-BUTTON-STARTER-SWITCH-HEAVY-DUTY_W0QQitemZ190092405439QQcategoryZ15329QQrdZ1QQcmdZViewItem
Post by: mikee on March 16, 2007, 09:39:06 AM
I had a similar problem that turned out to be blocked jets caused by washer additive.
If you go down the electric pump option you may be able to mount the push button switch inside the rubber pump on the dash, so it still looks original.
Mike :D
Post by: Dom on March 16, 2007, 10:39:53 AM
It's been decided, I will definitely go for the electric option. Thanks for the link Chris, I will buy that switch and try and mount it inside the original push. Also, how do you wire it in?
Mike, are the blocked jets cleanable, as I have a little collection of push pumps, and it would be nice to get at least one working before I rip it out and replace with electrics.
Thanks fellas
Post by: ChrisRLewis on March 16, 2007, 04:23:56 PM
Dom it's something like this:
(http://fiat126club.co.uk/forum/userpix/5_washerdiagram_1.jpg)
Post by: mikee on March 16, 2007, 04:33:42 PM
Hi Dom, I used compressed air to blow through the jets, you will be surprised just how much debris can come out of such a small hole.
Its easier to remove them for cleaning,you just need a 10 mm spanner.
Hope this helps
Mike :D
Post by: mikee on March 16, 2007, 04:34:01 PM
Hope this helps
Mike :D
Post by: 126dave on March 16, 2007, 04:45:54 PM
such a good idea you said it twice......luv it....
