Fiat 126 Chat => Fiat 126 Chat => Topic started by: punkydog on March 06, 2007, 08:49:17 PM
Title: Possible Stupid Question About Wheels
Post by: punkydog on March 06, 2007, 08:49:17 PM
My search for  small 13" Fiat wheels that have the lugs for hubcaps has been unsuccessful. I am struggling to find a happy medium with attempts to modify some wheels so hubcaps can clip on, they are either too tight then after a gnats wing adjustment too loose. The early 500 bolt thru wouldn't look right.
So here is my stupid question, small Triumph wheels have a pcd of 3¾" (95.25mm) and are 4.5 J and are plentiful. Before I research further would wobbly bolts wobble enough to allow for 2.75mm?
Post by: bis13 on March 07, 2007, 07:08:23 AM
thats between the four bolts , so i cant see why not , you can only try , why not have the wheels drilled out to 98 its easier to do in the long run.
Post by: punkydog on March 07, 2007, 06:01:17 PM
They are about as cheap as bis wheels and 3.5 J so I will suck it and see. But don't you have to get the hubs re-drilled not the wheels?
Post by: bis13 on March 07, 2007, 06:04:08 PM
no you can do the wheels , i know fiat fsm had some 100 mm pcd wheels drilled to 98 i can only assume its possible to go the other way as well.
Post by: dajwid on March 11, 2007, 06:37:25 AM
Old BMW wheels fit with no mods at all.
Post by: punkydog on March 16, 2007, 07:35:04 AM
Early Triumph wheels up to TR7 are lugcentric, that is the lugs centre the wheel. Fiats are hubcentric that is a snug fit on the spigot which centres the wheel.
I think that 500s which have the wide pcd are lugcentric but pretty much on their own anyway.
I am pretty sure 126s are hubcentric and that the bolts do little more than tighten the wheel against the hubface.
All new to me.
So I reckon if you use wobbly bolts to fit a wheel that does not fit the fiat hub correctly or fit wide spacers with out a centre spigot,you are going to have problems.
Aftermarket alloy wheels are supplied with spigot rings to adapt the wheel centre to the various different spigot sizes although quite often discarded after a few swaps.
Would be a good idea to list alternative wheels as a sticky as their is a safety issue.
All of which still leaves me four wheels short.
I believe I need 850, early 124 maybe 128 wheels, 13" must be steel and must have the lugs for hubcaps. Got some 124 hubcaps already.
Post by: bis13 on March 16, 2007, 07:46:37 AM
why dont you take the steeleys you have and weld on the holders for a hub cap?
Post by: punkydog on March 17, 2007, 09:36:29 AM
I had an experiment with that, snapped on a treat, wouldn't come off, filed a tad off - then too loose.
To be honest I don't particularly like the Bis style steel wheel with the holes, added to that I have a selection of styles, some have elongated holes and appear to be a bit wider.
The wheels on my scrapper are in a terrible condition
Posted a want on a Lada site. Looks like the first Ladas used 124 style wheels and caps.
I also have some wobbly bolts so 100mm pcd, 58mm hub is an option, so I will have a poke around the yards. Unfortunately around my neck of the woods the few yards left are are adopting a "No you can't just have a look attitude." probably due insurance liability.
How I yearn for the days of teetering five high piles of cars, huge puddles of sump oil and ferocious scrapyard dogs.
Post by: bis13 on March 17, 2007, 01:21:33 PM
i will have a look down my scrappy as they are a friendly bunch and let me climb around injuring myself no problem they even let you have a stupid plastic helmet to wear just to make you look a tit
Post by: ger on March 18, 2007, 12:07:44 AM
dajwid, how old BMW are we talkin......
